Thanks! I had cleaned the filter, but not the traps. I even went out & got one of those Lint Lizards. I cleaned the trap out, but the flashing lights & buzzing is still happening.:(Thanks! I had cleaned the filter, but not the traps. I even went out & got one of those Lint Lizards. I cleaned the trap out, but the flashing lights & buzzing is still happening.:(
You can't post conmments that contain an email address.
If it was transported likely the set was damaged--one of the three picture tubes used could have been damaged--the flashing light is the set trying to come on and the buzzing is related to whatever is bad.
Is the bulb light flashing ? - Sony's bulb light is very accurate in telling you if the bulb is bad. The buzzing sound could be from the balist trying to strike the lamp. You also may want to open the lamp door and see if the bulb is shattered.
sounds a s if you have ablockage within oyour pump assy, remove th elower acess panel and undo the "button trap" your problaby clogged up, the drain pump is humming, causeit cant pump any water
The flashing light is giving you an error code as there has been some sort of failure in the TV. The buzzing sound could be the flyback transformer. Count the number of flashes. I'm sure the code will be for the flyback.
Your control panel is getting ready to quit. Mine did the same thing, I ignored it and now nothing on the touch panel works. About $150.00 for the part.
