Question about Conair DPP1500 Iron
Iron Randomly turns off
The iron keeps turning off for no reason. It doesn't matter what heat settings. It will work for a week at a time and then for no reason shutdown and will not turn back on. Another time it will turn on and off. I think its a bad On Off switch I can hear a little buzzing sound sometime. I removed and checked all the contection and reassemabled. Problem continues.
The iron is only 18 months old and out of warrenty. I was thinking of boxing in up and returning to see waht would happen.
  • Anonymous Feb 03, 2009
    I cleaned my Digital Advantage iron (Black &Decker) and after that it keeps on turning off and I do not know how to remedy the problem.Any help would be appreciated.
    Thank you.
    Micheline Foster
    jjamesmiche@mchsi.com
    Scholar:
  • 62 Answers
I know in this economy, fixing a small appliance is always something to look at before buying a new one, but in this case, that is what I am going to suggest. An iron is an appliance that has the potential to burn your house down when it is in GOOD working order. It sounds like there is either a bad component, or there is an internal short. Either way, I would be safe and get a new one.
Hope this helps,
Chad
Posted on Nov 09, 2008
It is my first time using it, I brought it from USA and it is not working at all!!
follow this steps and fix it. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the electric cord and check the thermostat .
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat
If the iron does not spray properly, inspect and clean the nozzle
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Jun 11, 2013 | Black & Decker Irons
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
Bosch TDS 1445/05 Sensixx station doesn't making steam
HI!
I HAVE AN Bosch TDS 1445/05 Sensixx AND THE IRON PLADE NOT WORM AT ALL. I CHECK THE POWER.I CHANGE THE THERMOSTAT/THE CONDENSER WITH THE LAMP/.BUT STILL NOT WORK. THE BOILER WORK GOOD.PLEASE HELP ME.WHAT CAN I DO MORE. THANK YOU
Oct 06, 2012 | Irons
Does not turn on
please see the causes and use the common sense. God bless you
f the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
Sep 19, 2012 | Rival IR600 Iron
Iron keep shutting off while ironing
The cord is broken...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jun 21, 2010 | Black & Decker Steam Xpress AS250 Iron...
It leaks water when I iron sometimes staining my clothes with black streaks or water stains.
Hello :
1:Clean your steam iron according to the manufacturer's instructions. Your iron is more likely to leak when it has not been cleaned properly. Plus, the water that leaks from a steam iron that hasn't been cleaned will likely be dirty and stain your fabric. Every steam iron brand is different, so be sure to check the manual that came with your iron or browse the manufacturer's website for instructions on keeping your steam iron in good working order.
2:Use your steam iron on a rigid surface like an ironing board. In a rush, you might be tempted to quickly iron a blouse or pants on the nearest available surface like a bed, carpet or even on a table with a towel draped over it. However, these surfaces may not provide the proper amount of level padding for successful steam ironing, and leaks are more likely to occur. Take the time to set up your ironing board for smooth steam ironing to reduce water leaks on a bumpy surface.
3:Allow your steam iron to heat fully in the upright position before ironing. Because your steam iron is designed to convert water into steam that will easily smooth out wrinkles on bulky fabrics, you can avoid leaks by ensuring your iron has time to get the water to the correct temperature. If you lay your steam iron in the horizontal position too quickly, water that is not hot enough to convert to steam will leak. Give the iron a chance to heat up, and then test your steam function on your ironing board cover or spare fabric swatch before tacking your favorite blouse.
4:Turn off the steam function on your iron when ironing at lower temperatures. Since your iron's steam function is designed to convert the water in your iron to steam at the right temperature, lower iron temperatures can cause water to leak if your steam setting is still activated. For ironing more delicate fabrics, turn off the steam to avoid water leaks.
PLEASE RATE !
Apr 18, 2010 | Euro-Pro Shark GI490 Iron
Turn iron on but it doesn't heat up. It reads
Check the fabric settings and also if you don't move the iron with in a certain amount of time it shuts down for safety reasons
Sep 10, 2009 | Irons
Light comes on, but iron will not heat up
oliso iron turns on when plugged in green light flashes but iron will not heat up
Feb 13, 2009 | Irons
Conair DPP1500 Iron Logo
106 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
