Recently I am unable to retrieve voicemail messages from my phone. I have to check them using another phone. When it says please enter your password, I do, but then nothing happens. This also happens if I when I dial a # that has an extension, if i try to dial the ext it doesn't work. So I know the keypad works, but in these instances it is not. Any ideas.
-   HI, I HAVE THE LG KE 500 AND EVERYTIME I TRY TO CALL MY VIOCE MAIL FROM MY PHONE OR DAIL EXTENSIONS IM AM UNABLE TO.
IF I NEED TO ACCESS MY VIOCE MAIL, I HAVE TO DO SO FROM ANOTHER PHONE. IS THERE ANY WAY TO FIX THIS PROBLEM.-   PCRENS24
Mar 08, 2008
-   how do i access voicemail in the panasonic gd55 phone?-   rg7733
Dec 26, 2007
-   i can't retrieve my voicemails for my razor? it won't left me enter my password...any solutions-   meghan07
Dec 26, 2007
-   i have the same problem...any solutions? please help-   meghan07
Dec 11, 2007
-   how do i check my voicmail messages. please help. thanks.-   llam
Change the DTMF found in phone settings (Initial Set-up) to either short or long. When this is set to off, the voicemail cannot pick up the numbers you type.
shush... indicated that his solution for i860 Problem is valid for all Cellular Phones
If you're not getting access to your V Mail, you need to reset the phone. It should be under the the Advenced portion of the Security setting. Default code is all (6) zeros.
It sounds like your DTMF tones are turned off. This would cause automated systems to not recognize the buttons you ae pressing. Go to settings and initial set up and make sure you dtmf tones are set to long.
yeah i had that problem too. its because you do not have the voicemail feature on ur account. so you have to go activate it. just go to your service provider.
how can i change my phones language from spanish to english? All displays are in spanis now. My...
(More)
how can i change my phones language from spanish to english? All displays are in spanis now. My phone is motorazer v3
