Home | Dacor | Epicure ERD36 Dual Fuel (Electric and Gas... | Cleaning Oven Door Gla...
Dacor Epicure ERD36 Dual Fuel  Kitchen Range
Problem for Dacor Epicure ERD36 Dual Fuel (Electric and Gas) Kitchen...
Cleaning Oven Door Glass inside face
By ronr408 on Nov 09, 2008
We were recently fixing a dish in the oven which required us to bake liquid milk/cream. As we were putting the dish into the oven it spilled onto the open oven door. Some of the liquid entered the vents at the top of the door. After cleaning up the spill the dish was place into the oven and the door was closed. As soon as we did liquid ran down the inside face of the class which appears to be inaccessble. There is nothing in the Dacor manual about cleaning or getting to the inside of the glass. Is this somethign that we can do ourselves or do we need to call a service technician?
Same Problem
Apr 11, 2009
-   same prtoblem here too - but on a Amana ARG7600LL gas range. Can't get to the inside of the glass door to clean. -   thomsonfamil
Feb 02, 2009
-   I have a GE self clean oven and the same thing happened to me now there's a drip on the inside of the glass door, I'm afaid to unscrew the window screws as the owner's manual says not to mess with any of the gaskets.....What to do? Is the only answer to call the tech. Thanks for any any help-   neoneo31
Best Solution
posted on Dec 16, 2008
Helpful)
MBTCJ
Rank: Apprentice
Rating: 83%, 2 votes
WE HAVE A KENMORE OVEN AND WE TOOK OFF THE HANDLE WHICH RELEASED THE OUTER GLASS AND WE WERE ABLE TO CLEAN IT - THE ONLY PROBLEM WE'RE HAVING NOW IS THAT WE CAN'T GET THE GLASS BACK CORRECTLY. WE MAY HAVE TO REMOVE THE OVEN DOOR TO PUT IT BACK ON. HOPE THIS HELPS.
Was this helpful?
Yes
No
Solution #2
posted on Mar 11, 2009
Not Rated)
kam_rentals
Rank: Apprentice
Rating: 0%, 0 votes
First take the two inside screws out, (found at the top of the door) they will pop out when you have both sides off so make sure to take them all the way out so you dont lose a washer or one of the screws. The handle is actually secured by these 2 screws and will come off of the door when you remove them.. your metal door can bend slightly in this process, so be careful. as soon as the handle and screws are off you can clean inside of the 2 pieces of glass, also a good time to clean off the opposite side of the door behind the handle. only take the 2 screws off no need to remove the full door. I used a magic eraser to remove the grease and then I cleaned the glass with glass cleaner. I used a small vice to secure the door when putting the handle back on, but you could have someone to hold the piece togeather for you too. (I have a frigidaire stainless steel model)
Was this helpful?
Yes
No
Popular Solutions for Dacor Epicure ERD36 Dual Fuel
Questions and Unsolved Problems for Dacor Epicure ERD36 Dual Fuel
Do you recommend Dacor Epicure ERD36 Dual Fuel (Electric and Gas) Kitchen Range?
Answer
Answer
when i select bake to preheat oven the bake element does not glo on only the broil burner. then when... (More)
Answer
I have a similar problem with thr F1 warning alarm that goes off at all hours of the day and night.... (More)
Answer
We have had a problem with the control panel since we bought this unit. Dacor rep says to turn stove... (More)
Answer
Can you suggest a solution ? The guide indicates F1 means ""Element relay circuit...
Answer
This is a caravan oven and has been out of action for this summer period any help is gratefully... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dacor Epicure ERD36 Dual Fuel ...:
Top Kitchen Range Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Kitchen Range Experts
Top Range & Oven Repair
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
