Question about Craftsman 8.50 Torque Rating Dual Rotating Tine Tiller
What type oil does it take
Model #917.294261
  • joethefixr May 11, 2010
    what is the make of engine?
  • 163 Answers
5W 30
Posted on Nov 30, 2008
How much oil and type of oil for my craftsman 42" mower
Oil capacity and type depends on engine size, manufacturer of the engine for the mower and whether it has an oil filter too. There should be a label stating model number near the battery that is under the seat, or it may have information for oil volume inside mower "hood". If you get the model number, it's possible to download a file for the manual at no cost.
Nov 01, 2017 | Craftsman Garden
In changing 2005 Harley Heritage Model FLSTCI fork oil, how many ounces of fork oil should I use? What does wet or dry mean?
I'm sorry but I don't have the specs on the quantity and type of fork oil for your year and model bike. I work on the older bikes that the dealers will no longer service. But, I can describe the difference between the "wet" and "dry" conditions of the fork assembly. If you take the front forks apart, clean them out, and put them back together with no oil in them, they are considered "dry". For a simple drain and refill type oil change on them where you don't get all the oil out of them, they are considered "wet". I hope this helps, You can call you local dealer's service department and they should tell you the quantity and viscosity of the oil that goes in the front forks on your machine. They'll tell you something like 6 ounces of "Type E" oil, for example. Harley-Davidson uses these types of specs to describe their oils. If you go to a website for fork oil, like PJ1, they may give a cross reference or equivalency chart for converting H-D "Type E" to their oil. I think that would be their 30 weight oil. If the front end seems too "stiff" with 30 weight, you can drop down to 20 weight. I think Honda makes a 25 weight but not sure. Your Harley won't mind the Honda oil. BG.
Good Luck
Aug 23, 2011 | 2005 Harley Davidson FLSTC - FLSTCI...
Do you use 4 cycle oil or 2 cycle oil for pressure washer EXH2425?
For your model pressure washer you should not be using 2 or 4 cycle oil. You need to use the following:
Model # EXH2425 P 2400PSI 2.5GPM 5.0HP HO
**Annovi Reverberi (XMV) 30W non detergent 13.5 oz.
**Annovi Reverberi (RKV) 30W non detergent 18.54 oz.
Aug 15, 2011 | Garden
What type of oil do you use for 21" rear discharge
The type of oil would be SAE 30 or 10W / 30 Motor oil
Jun 26, 2011 | MTD LAWN MOWER PART # 603-04196 TUBE...
It holds 6.5 quarts (6.1 Liters) of 5W-30W oil with filter change.
May 31, 2011 | 2004 Jaguar X-Type
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
Do you have to use oil in the pump and if so type,how often.
water pumps doesn't require oil in the pump; but your engine does require. if the water pump is of "self priming" type, fill the pump casing with water before starting the machine to avoid damage to the water seals.
May 22, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
Manual for Skil Saw model 77 type 17
I have a Skilsaw model 77 type 16. I have the original owners manual and would be willing to fax you a copy.
The manual only lists a part number for the gear oil, it is No. 249. This is for a 5-3/8 oz tube of gear oil. I checked with my local hardware store which services this saw and they called a factory rep. They told the hardware store with shipping and handling it would cost about $17 for the oil! However they also said that a 90 weight gear oil is close enough to solve the problem.
Hope this helps.
Sep 22, 2008 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Craftsman 8.50 Torque Rating  Dual Rotating Tine Tiller Logo
113 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
