Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint WT960 Fault F-07 heater relay
Machine is stopping half way through cycle and shows fault F-07 heater relay - where and what is the heater relay, if turned off and switched back on and put on rinse and spin it works???
  • Anonymous Nov 18, 2008
    Same as above
  • 3,230 Answers
A few reasons for this, faulty heater, broken wire, faulty pressure switch or faulty main control board (the heater relay is on the main control board).
There is no reset for this.
Unplug the appliance and take the rear cover off.
Check the wiring to the heater and thermostat. Give the wires a good tug as they can break internally and look ok.
If you have a multimeter, test the heater, it should read around 25 ohms.
Take the top off the appliance, locate the pressure switch (has a thin tube on it), give it a few good taps with your screwdriver handle.
Finally, take the main control board out (bottom left when viewed from the rear) and one plug at a time, take them off, clean and tighten them, plug them back on.
If everything checks out ok, then it's likely the main control board is at fault.
Good Luck!!
Thanks
Posted on Oct 01, 2009
Hotpoint washing machine wt960 not working because fo8 code come
Hi Hitendra,
F08 is a sticking heater relay. First check that connections on pressure switch are good, Check that heater connections are good.Check the board connections.Check that pump filter is clear.
Hope this helps!
Wayne
Nov 20, 2014 | Hotpoint Washing Machines
Hotpont washing machine wt960 fo8 code m/c stop
I believe F08 Error code is for a Heater fault
Issue: During a wash cycle the programme pauses part way through.
Error code f 07 mid cycle?!?
You do not state your machine or model. The error code F07 that I have states that the Central Control Unit has detected a short in the Motor Control Unit.
Check the wire harness between the Drive Motor and the MCU and between the MCU and the CCU.
Check the MCU.
Check the Drive Motor.
Check the entire wire harness.
Replace any defective parts.
Apr 26, 2011 | Washing Machines
My hotpoint washing machine wt960 keeps displaying the fault code f-08 when trying to do a 40 c wash
Error code F08 is indicating that the heater relay cannot be activated.
Check all connections on pressure switch----module---- and heater.element.
Hope this helps, this is the recommended procedure.
Dec 01, 2009 | Washing Machines
Hotpoint ultima washing machine is showing a fault
F 05 normally means there is a blockage or a fault with the pressure sensor. The common place for blockage is in the black pipe from the drum to the pump as it has a filter in here and clogs up. remove the pipe and clean the filter out and remove gunk from the pressure sensor on the side of the pipe as well. If that does not fix things the pressure switch could be faulty itself
Sep 13, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WD860 - Fault Code F-07
F07 indicates heater relay stuck.
You need to check the heater to see if it is faulty, and fit new one if it is.
Please rate my solution.
Thanks.
Jul 10, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hot point f-08 fault code
F08 means that the heater relay cannot be activated.
Suggest you check heater, and or thermistor (thermostat) for a fault, replace as req'd.
Please rate my solujtion.
Thanks.
May 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint fault f-07
F07 means that the heater relay is stuck, you need to test the heater and replace if req'd.
If heater o/k then you still have a problem with the heater circuit somewhere.
Maybe a control assy
Plz rate this solution.
Thanks, and a merry xmas.
Dec 20, 2008 | Washing Machines
Hotpoint ultima wt960 washing machine noisy on spin
Bearings faulty or another fault this model suffers from is the concrete balance weight retaining bolts shake loose, if it is the bolts tighten up as soo as possible. Regards Advisor
Aug 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
880 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
