Question about Panasonic NN-S933BF Microwave Oven
Turns on with door open
Hello, we own a panasonic Invertor serial# 6A23280963 model# NN-S933BF Our microwave is turning on with the door open. It runs fine other than that. Presently we are having to unplug it to place our stuff in the oven. Then we plug it back in so we can run it. We just need to know how to reset the computer inside it so it will not run when we open the microwave oven door. Thank you for your assistance. Maria Stephenson
  • unicorns99 May 07, 2009
    Panasonic NN-S933BF turns on when door is opened. works normaly otherwise
  • Panasonic Master
  • 9,098 Answers
It's likely that it's only the fan and light coming on when the door is open. But even so, it's not normal, and it should be fixed. It's not a reset issue. It's likely a broken door switch mount caused by a door slam or by inferior material, or a defective door switch caused by opening the door while the oven is cooking instead of hitting the "STOP" key first. You can do a Google search for my text file "doorsw.txt" which will give safety info and help in checking the door switches. Also, the plastic pieces on which the door switches are mounted should be checked, as well as the door alignment. It's usually the upper door switch or mount that causes this, but occasioanlly it's a problem on the control circuit board. Post again if more help is needed.
Posted on Oct 25, 2006
Light nn-sa651s
Panasonic FAQ:
The microwave oven model NNSA651S was manufactured in a way that the oven light turns on only while cooking. - FT
Stupid design!!
Feb 19, 2013 | Panasonic NN-S541 Microwave Oven
Microwave fuse keeps blowing on my Panasonic Microwave NN-9854P
I would check the door interlock switches and then if that doesn't fix it replace the invertor board and possibly magnetron.
Feb 21, 2011 | Panasonic NN-P295SF Microwave Oven
Microwave will not shut off when the door is opened. Keeps operating
The door switch has gone bad...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 11, 2011 | Panasonic NN-S933BF Microwave Oven
Model NN E 548W The Microwave does not switch on.The Fuse on plug is OK.What solution?
THis type of microwave, invertor, is particularly awkward to work on if not trained by Panasonic.
I reccomend an authorised Panasonic repair agent take a look at it.
Jan 12, 2011 | Panasonic NN-P794SF Microwave Oven
Panasonic Model No. NN-S933BF Microwave Oven
No sorry the issue will be with eiher the inverter, the magnetron or the main timer board. There is a tracer signal that comunicates through these components and if it doesnt get to where it is supposed to go it wil just shut off, the big hint at that is the time interval. It is not something like a sensor heating up and causing a fault. it is not running long enough to get any thing hot it is in the electroincs. Too expoensive to repair, im sorry better to get a new one. Good Luck
Jun 17, 2017 | Panasonic NN-S950BA Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Oct 04, 2008 | Panasonic NN-T990SA Microwave Oven
Turning off before finishing time time cycle
I have just had this problem where the oven will only run for 5 seconds and then turns off model #NNS561. Cant find any solution.
Jan 19, 2008 | Panasonic NN-S950BA Microwave Oven
Open Questions:
Panasonic NN-S933BF Microwave Oven Logo
339 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
