RCA F31671SE Turns on nothing else.
I picked up this T.V. with a broken off cable connection. Was told it still worked with S-Video. Tried it and all I got was a blank screen. I am carefully looking at the innards and thought I would ask if there is any thing in particular I should check before I take it to be fixed, toss it or maybe make it a learning fixit project. nothing into it so nothing to lose and only knowledge to gain.
    President:
  • 2,992 Answers
Do you have sound with the blank screen? Some RCA sets had a screwy design problem where an s-video signal wouldn't show up unless you had a cable plugged into the normal video connector as well, so you might give that a try (that is, plug in both regular and s-video cables from the source, then select the s-video input). The broken-off cable connector is repairable (replacement connectors are available) but it means soldering both large and small connections in tight spots, so it might be worth calling a service technician if you are planning to keep the set.
Posted on Nov 10, 2008
My RCA 42 inch TV turns on but I see nothing but different color lines on the screen and no sound.
Lines on the screen usually is a problem with LVDS board, panel or the ribbon cable to the panel. Set should have audio though. the main board processes both audio and video but will not produce colored lines.
Feb 03, 2015 | RCA L42WD250 42 in. LCD HDTV
Our Wii turns on - with sound but no picture. Our cables are connected right
I recommend trying a different television set. That can eliminate the Wii or the TV as the issue. You might have a bad cable too, I know those RCA cables can look OK but have broken wires inside the insulation (assuming you are using RCA cables)
Dec 20, 2011 | Nintendo Video Game Consoles & Games
VIDEO 1 AND VIDEO 2 DON'T WORK WITH SATELLITE. VHF WORKS BUT NO SOUND
First of all check if theSatellite box or the RCA cable is working ok with other equipment/TV if they both r working fine then their is an internal problem with ur TV.Show it to a authorised service person.
Jun 01, 2009 | Televison & Video
RCA DRC8030N No output
Connect the unit as you normally would using the composite cables. Once you turn the unit on and the RCA logo flashes and then the video *poof*, dissappears, press the Video Out button on the remote control so that the PS OFF (progressive output for S-Video) is shown on the LCD, this should get the video back to normal.
Nov 09, 2008 | RCA DRC8030N
Connecting DVD player to AV receiver
If you've done that already and still no response from your system, I would suggest to take back to the place where you bought it and ask them to check it for you. Tell them that you follow the user's manual to the "T" but still unable to make it work.
Good Luck.
Jun 20, 2008 | Denon AVR688
Connecting Denon receiver to DVD player
Normally the optical inputs are disabled unless specifically turned on. I dono't know your specific model. I'll research the model and update this with more specifics.
Dan
Jun 17, 2008 | Denon AVR588 Receiver
DVP642 DVD Player is only working in Audio mode
Mine does the same. Cannot get a picture using the Yellow RCA output. Use an S-video cable if you can - it should still work. If you get a black and white picture using the S-video output, go to MENU > VIDEO page and change the output from PyBywhateveritis to S-video and the color will come back. I only found out mine was broken when I needed to use the s-video cable for something else and tried switching to the Composite Video (RCA) to no avail no matter how many cables or TV inputs I tried.
Mar 15, 2008 | Philips DVP642 DVD Player
Unusable Signal
Hi. What you need to do is plug in a cable or Antena in its place, and reprogram the channels. if you did that, then try to use a VCR or DVD player and install it using the RCA cables. Install the cable to the DVD or the VCR. If nothing works, My TV has a crack in the LCD. I'll either sell it to you, or buy yours. Let me know. Thanks.... email me to hajum30@yahoo.com
Thank You...
Sep 29, 2007 | RCA L46WD22 Television
Set up with daytron TV
Have you tried hooking up the VCr and TV using RCA cables? You must connect Video out from VCR to Video IN of Tv and Audio out of VCR to Audio IN of TV.
Jun 01, 2007 | RCA VR546 S-VHS VCR
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
