Question about Dayton Electric Heater
Dayton electric garage heater
I have a dayton 3UG73D garage heater and everything is properly wired but it only runs on low speed.I can not get it to run on high.
    Problem Solver:
  • 8 Answers
Need to check you fan wires, some have differant colors on the moter for the differant speeds, you may need to change the fan speed by unplugging one of the wires and replacing it with another. hopefully you still have the manuel , check with it first!!!
Posted on Jan 07, 2009
Dayton heater mod 2yu59 is not heating up?
Need to check the low voltage circuit for 24 volts, the 480 volt to 24 volt transformer may have a circuit protection reset or fuse installed. All the 3 phase electric heaters use a low voltage control circuit for operation of relays (24 volt coils).
Nov 22, 2011 | Dayton 2YU59 Electric Heater
I just instlled a Dayton 3UG73D garage heater and the motor has stopped. It still heats up but the motor will not come on
Check for loose or disconnected wire especially to the hi-limit switch or fan switch.
Dec 16, 2009 | Heating & Cooling
My dayton NG heater fan will not shut off properly
Sounds like a bad fan switch. The switch is located on the heat exchanger and is 110 volt bi-metal switch. Follow the wires from the blower going back to the heatexchanger. Graingers can get you a new switch if you give them your model number. www.grainger.com.
Dec 12, 2009 | Dayton Heating & Cooling
I have installed a Dayton G73 heater in my garage along with a 240V outlet. I am using a 3 prong dryer cord and I am having difficulty figuring out which wire to hook to L1 and L2. I have determined the...
here's a link to the install guide
www.air-n-water.com/manuals/G73.pdf
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/Installation-Dayton-G73-Garage.htm
Nov 02, 2009 | Heating & Cooling
I have a 3ug73d heater I would like to put a real thermastat on it.How do i wire it.
is this a baseboard unit? the thermostat kit has four wires - a black and a red, a black and a red. for 240 volt operation, both line wires go on the two blacks and the heater load goes on the red wires
Oct 13, 2009 | Dayton Heating & Cooling
Need wiring info on DAYTON 3E342A. All info needed .
if you will google the make and model number you should find a pdf owners/ service manual
Dec 17, 2008 | Dayton Electric Heater
Installing a Dayton G73
How many amps is your service? And what gauge wire did you use for the heater?
If your service is only 40amps that is your problem. You don't have enough amps for the heater and the rest of your house, you will have to upgrade your service.
Nov 02, 2008 | Dayton G73 Utility Heater
Lot of the wires came off the on the back of the Heater
We have a Dayton Unit Heater in the garage, gas. the wiring is a mess do you have schematics?
Sep 23, 2008 | Dayton (3E386) Heater
Dayton Electric Heater Logo
311 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
