Question about Epson Stylus® C64 InkJet Printer
Epson C64 Printer
Hi.
I have a C64 printer. a paper jammed i removed it okay but now when i turn the printer on it makes a strange noise for a few seconds and then the two red lights start flashing could the ink carraige be jammed what can i do?
Thanks.
  • Gerry Millward
    Gerry Millward May 11, 2010
    The two flashing lights do indicate that the print head cannot move either due to paper or something else jamming it. Can you post a new comment saying whether or not you still have this problem.If so, I can help you with it, if not we can close it as solved.
  • 353 Answers
It sounds like the print head is jamming on the parking mechanism (usually because the actuation lever is stuck in the up position). Turn the printer on, and as soon as the print head moves, pull the power cord out of the back, or switch it off at the mains. You should now be able to move the print head over to the left by hand out of the way. Now look in the "parking bay" at the right end where the print head parks itself and see if there is a plastic arm sticking up. If there is, gently pull it towards you and it should spring down. Now turn the printer back on and it should operate normally. If it happens again, repeat the process a few times to see if it clears the problem. Otherwise it means the parking mechanism is gummed up with dried ink and needs a good clean (see below).
Alternatively, if you see that the whole parking mechanism itself has moved up to block the way, this means a spring has come off. To get this back on again requires the printer to be dismantled - as does the cleaning job above!
Should you decide to have a go at cleaning or re-fixing the spring, let me know via a new posted comment so I can provide further assistance.
Posted on Mar 08, 2009
Paper jam
Epson stylus paper feeder keeps jamming
Feb 16, 2014 | Epson Stylus Sx535wd
Ink and paper lights flashing alternately epson c64 photo edition. paper fine, ink levels fine, power fine, comms with computer fine, still wont work, Help.
-turn off printer
-disconnect from computer
-load a couple sheet of plain paper
-press & hold paper feed button while turning the printer on
-it should print a test page if it is working fine, otherwise it is bound for service
Apr 02, 2010 | Epson C64 InkJet Printer
Grinding noise when I turn it on
Ive solved the problem, I took the side panels off, and found a piece of paper jammed in the gears, not sure how it go into the place where it was.
If anyone gets this problem, use the Epson disassembly guide found at: http://www.eserviceinfo.com/download.php?fileid=12748
Thanks!
Jan 01, 2010 | Epson C64 InkJet Printer
Canon Stylus C64 paper jam
try this link below. Although the printer is lexmark but it can used the idea to solve the problem regarding paper jam issue.
http://www.lexmark.com/publications/pdfs/lexmarkt522/eng/paprjams.pdf
Thanks
Jul 31, 2009 | Epson Stylus C64 InkJet Printer
Epson 1280 ink carriage making noise and not printing
hello there. try re-seating the cartridge. Take it out, then put it back in.
Nov 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
Strange noise
dear cindy726
your printer is having a hardware failure.please sent it for serviced
Apr 07, 2008 | Epson C64 InkJet Printer
Problem with epson stylus C64
why wont my printer work? IT HAS INK AND PAPER AND IS CONNECTED. IT DID PRINT A FEW DAYS AGO!!!
Nov 06, 2007 | Epson Stylus C64 InkJet Printer
Epson Stylus® C64 InkJet Printer Logo
73 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
