Question about Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop
Dell e510 won't make it to post
My problem started with the blinking amber light that so many have had trouble with. Tried all the initial fixes recommended by various people on this site. Next, I installed another power supply and had the same results. Now after installing a new motherboard, I don't have the amber light, but the computer will not make it to post. It seems like it is starting to boot up and then quits before gettting to the video, because nothing comes up on the monitor. I've tested the hard drive in another computer, the video card, and even put a new processor in the board, but still nothing. Also I tried some ram from another computer that I know is good, but still nothing. Any suggestions would be appreciated.
  • 1 more comment
  • woodchuk5195 Nov 09, 2008
    TN, tried what you said with no results. I've tried multiple power supplies and that does nothing either. The diagnostic lights on front are as follows: light one is green and blinking, two is off and three and four are green and solid. Does this mean anything to anybody?
    slick, i've tried the monitor on another computer and it is fine.
  • webicine Mar 25, 2009
    I have the same problem and am wondering if you ever resolved this. I have replaced the motherboard and power supply. PC won't post... green power light comes on for about 2 seconds then everything shuts off.
    Scholar:
  • 60 Answers
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on). If you purchased a non dell power supply, you might try this with the original one installed.
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Posted on Nov 09, 2008
    New Friend:
  • 127 Answers
The Main Board Is Defective Or Used And Dammaged Beyond Repair In Wich Case If You Paid For It As New
Then Hire An Atterney Because You Have A Case Against The Merchint! They Riped You Off! Take Them To Court!
Posted on Apr 27, 2014
    Scholar:
  • 126 Answers
Have you tried a different monitor?
  • Slick54 Nov 10, 2008
    Sounds like there is a hardware compatability issue, if you have changed out all those things, the problem may be with a piece of hardware you are using that tested ok with anonther computer. Is the video card specs compatible with the motherboard? It seems to be failing at the video level, make sure the video card and the video card memory meet the motherboard specs, if you are trying to use a video card with DDR memory on a motherboard that does not support it, failure is emminent. Make sure all hardware and memory meet the correct specs, let me know what you find.
How do I fix a dimension E510 with a solid amber power light?
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 25, 2014 | Dell Dimension E510 PC Desktop
I've got a Dell Dimension 5150. After connecting to the mains the power light is blinking amber for some time, it then disappears and only then the computer can be booted. Unfortunately this delay is...
Check POST Boot messages for a flat Battery; Check Front control panel circuit over (remove); Check other USB connectors; Try a replacement Power Supply Unit.
Sep 12, 2010 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell Dimension power button flashes amber and will
open up your system get a can of air and blow all dust away could be an overheating fault
May 13, 2010 | Dell Dimension™ E510 PC Desktop
My power botton is blinking amber
Hi, the amber light means your computer experienced a hardware failure. You'll have to test your hardware and memory to find which component failed.
You're welcome to ship the unit to me for repair; I'll test the components and notify you regarding the necessary repairs prior to fixing it.
There is a $25 diagnostic charge. Email me at buffalonymann@yahoo.com if you want to proceed
Nov 05, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Blinking amber light and wont boot up.
if the power button was blinking amber, unplug your tower, and hold the power button for 30 seconds to 1 minute, to use any excess power stored in the capassitors in the pc. this was told to me by a dell tech, it is a small issue with the 3100=E310, and 5150=E510 Dimension desktops
Sep 24, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Will not start up, power button flashes amber color
Disconnect ethernet cable. In bios, disable the "boot from network" option. Reconnect cable. Restart.
Sep 03, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop Logo
1,032 people viewed this question
Alun Cox
