Question about Acer X163WB Monitor
Monitor tint is blue
The dogs pulled my monitor plug out of the cpu and bent it alittle. I straighten it out and plugged it back, but the screen has a blue tint to it. How do I fix this?
thanks
    Genius:
  • 1,400 Answers
Purchase a new vga monitor cable.Staples,Best buy,has them.
Double check your connection at the back of the pc for any damage.
Posted on Jan 13, 2010
    Problem Solver:
  • 8 Answers
U just take it to a comuter place and pay 5 to 8 dollars to bye a new cord because even though u put the cord back the way u think it was the inside of the cord is damged and try to keep your dogs away next time but im sure your already doing that?
My screen has gone to a blue tint. What is the life expectancy for a screen?
Blue tint (Red tint, or Green tint) is more likely due to one of the pin on the VGA cable is bent ot the cable is not seated properly of the the video card conectors may be the problem. Try it with another PC and check the pins.
LCD monitors usually fail after about two years due to bad caps.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find
Nov 14, 2010 | Sceptre S1902D 19" LCD Monitor
The color on the monitor suddenly has a blue tint that I am not able to change.
have you removed any of the VGA connectors at all ? - have a look on the plugs for a bent pin - quite a common issue on VGA plugs - that even when bent they will still screw into the socket and depending on which pin you can get a colour shift
Apr 12, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
I unplugged my Acer al1914 monitor from my computer and plugged a different acer al1914 in my computer and now when I transfer the screen from notebook to monitor it has a blue tint on the entire screen. I...
Check the color settings in the on-screen menu. You can choose between "Warm", "Cool" and "User". Maybe you used the "Warm" setting before and somehow it got changed to "Cool".
If this is not the case, you can try the "User" mode and reduce the intensity of the blue channel.
If even black areas show a blue tint, maybe running an auto configuration from the menu helps.
As a last resort, use the "Reset" menu item which resets all settings to factory defaults.
Mar 30, 2010 | Acer AL1914 19" LCD Monitor
L have not yellow colour and blue in my screen,,,
assuming you have a VGA monitor, disconnect the video cable and inspect the pins. Check to make sure that the pins are not bent/crushed or missing (there should be 15 pins in 3 rows). You may need to look at both sides of the cable. If they are crushed/bent, replace the cable if possible. If not possible (because your cable is hard wired to the monitor), try VERY GENTLY to straighten the pins
Mar 07, 2010 | Computers & Internet
I use the Optiquest monitor as a dual screen and it has a pink tint to it now. How do I fix?
This could be one of a couple of things.
1. The cable that you are using may be damaged, if so, wiggling it back and forth / tightening the connection / looking for bent pins on the cable and straightening with help to diagnose. Replacing the cable is the best remedy.
2. Check if Internet Explorer 7 or higher has been installed. If start Internet explorer, click tools, internet options, advanced and switch off the "Always use clear type for HTML" option.
3. Check if the red tint is still there when not using in dual screen mode. This will highlight a configuration issue with the dual screen setup.
4. Try a different refresh rate, RGB colour balance, resolution, etc to try and fix the issue.
5. Try the monitor on a different PC.
6. Try a factory reset on the monitor.
Nov 08, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Green tint display
The monitor is faulty, not enough red. you can make changes in your display advance settings to try and reduce the yellow and blue to make the screen look a bit better. you might want to try a differant vga cable or check the pins in the plug that nun are bent
Aug 18, 2009 | Star Logic 17" LCD Monitor
Mymonitor is an AOC 1770 CRT, it have a light
make sure you dont have a bent pin on the cable where it plugs in. a bent pin will make different things happen to your colors. if the whole thing is tinted, yellow, or purple it usually is an issue with the plug. also, if you have an old screen plug it in and eliminate the video card as the culprit.
Jun 19, 2009 | AOC 1770 17 in.
Blue color tint on monitor. color is not right.
one thing to look for is the cable from your monitor to your video port remove the cable from the back of the computer and check to make sure there are no bent pins. If possible revovefrom monitor and check thos pins as well
Dec 27, 2008 | E-Machines eMachines Monitor E15T4
Blue tint on computer display monitor
Try
1. Unplugging the video cord from the back of the computer (and screen if it comes off) and plugging it back in. Sometimes it can become loose and cause a screen to have a abnormal color contrast
2. Updating the drivers to your card
3. Trying a different monitor on the computer. Mind you, if you plug in a differant monitor and the color stays the same. Check the videocards pins on the back of the card. I dont know if you gave all the info on how it became like this, so maybe it got undone and plugged back in forcably and one of them got bent? I
Also if the pigment goes away. Plug the normal one back in and if its gone, great!, if its back. Try the OSD settings on that monitor. Still no luck. The monitor is junk.
Hope that helps
Nov 30, 2008 | ViewSonic Computers & Internet
No Signal Detected
Is this on a notebook or on your regular PC?The answer will determine what the solution is. You can first check to see if the little pins on the plug are all straight and none are bent or broken. If one of he pins is bent then you can try gently straighten it (unplug the monitor from the wall first) If any of the pins are broken then either the cable needs to be replaced or the monior has to be replaced.
Jul 14, 2007 | BenQ FP91G+ 19" LCD Monitor
Acer X163WB  Monitor Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
