Question about ICOM Informatique M402S Base CB Radio
Icom m402 I GOT A PROBLUM WITH ONE OF MY ICOM M 402 RADIO. ITS NEW ONE BUT WHEN I ON THE UNIT THE LCD IS GETTING ON AND OFF (BLINKING) I HAVE THE ICOM CLONIG PROGRAM .HOW I SOLVE THIS
    Genius:
  • 1,139 Answers
You may have poor connections on you LCD screen leads. I would first determine if the blinking is being caused by a loose connection or by something happening within the CB circuitry. The best way to do this would be to try to push and hold the LCD screen to stop the blinking if this works then your trouble is a loose connection. If it does not work then you may have some kind of internal problem. One such problem would the the IC driving the LCD screen you will need to have a schematic to troubleshoot this. The schematic will show you the voltage readings that should be on the pins of the LCD driver IC, and by measuring the voltages you should be able to determine which components are defective. You may also want to use a logic probe if the schematic contains a truth table of the states the pins sould be in under test conditions.
Posted on Sep 05, 2007
Can I use an Icom AT-180 ATU with my ICOM IC-7300 HF radio
AT-180 ATU is not intended for IC-7300. Icom IC-7300 have a built-in tuner already. maybe you can use a special cable or interface to use the AT-180 on IC-7300.
Feb 18, 2018 | Icom Radio Communications
Charger battery
What is the actual question? You can get replacement battery chargers from ICOM parts depot, look them up at www.icom.com, or get a universal charger from a local Amateur Radio dealer.
Aug 27, 2013 | ICOM Informatique Icom Radio IC2GXAT,...
Rx error on a210
replace the riben cable from head unit to main board,£2 from icom uk. regards gw0dxo
Jan 16, 2013 | Icom IC-A210 VHF Airband Transceiver
How to find icom bc-177 sofware ?
I'm totally confused by your query my friend...
You have an Icom desk top charger, do you have the Icom radio that goes with it?
Software for hand held Icom radios is can be available, but for the Icom battery charger, NO is the answer.
Cheers,
Peter
Jul 08, 2012 | Icom BC-177 Desk Top Charger
I bought a new logic unit (front face) of Icom F121 and it needs to be restored. How do you restore a logic unit for the Icom F121?
1- You have to to "Reserve" mode.2- Change Set Mode Access: Inhibit to Enable3- Common>>Secutity Change Set Mode Access : Inhibit to Enable4- Enter RX TX frequency and write to the radio.
or you can download version Rev 1.7 from here:
http://www.two-way-radio-tools.com/icom-softwares.html
http://www.two-way-radio-tools.com/icom-radio.html
Aug 27, 2010 | ICOM Informatique IC-F121 VHF 136-174MHz...
M402 didnt receive the gps signal transmitted by garmin 72 via nmea 2.0
Check the wiring again. Installing my M422 needed to switch the polarity of the NEMA input from my GPS75. May be similar problem
Oct 23, 2009 | ICOM Informatique Icom IC-M402 VHF Marine...
If you where going to Buy one radio which one would you Buy?
I am a marine electronics technician with 28 years experience. I have also been a licensed amateur radio operator for the past 12 years. Based on my professional experience with both brands (Icom and Yaesu), I have to advise you to go with one of the Icom units. The Yaesu is a good radio, but Icom's customer support is far superior. I have had no problems dealing with their service department over the years, something I can't say about Yaesu.
Hope this helps.
Feb 21, 2009 | Icom IC-R5 Handheld Scanner
ICOM F43TR
Chris, How is it that you programmed your radio. Do you have the software for this radio? if so please send me a copy of the saved radio file so that I can make sure that all the settings are correct.
Pat
vrc-repair@sbcglobal.net
Jul 28, 2008 | ICOM Informatique Icom Radio U16, IC2GAT,...
ICOM Informatique M402S Base CB Radio Logo
182 people viewed this question
Top ICOM Informatique Radio Communications Experts
Steve
ka4iup
ka4iup
normis101
Are you an ICOM Informatique Radio Communication Expert? Answer questions, earn points and help others
