Question about Epson Stylus Color 760 InkJet Printer
Epson Stylus color Printer prints strange lines and doesnt use all colors
My printer has all of a sudden decided to print strange lines across my printed documents i get different colors on each attempt it seem like the inks are blocked but if i do a nozzle check it seems clear what is wrong? i recently put new cartridges in too cuz i thought it was empty.
  • 1 more comment
  • Steven Luckham Oct 25, 2006
    Hi thanks for the reply,
    You say check the cartridge alignment what does that mean? im a novice really with printers all i know is how to put the cartridge in and use the cleaning utilities to unblock nozzles i have tried uninstalling the printer driver ive just recently reformated my hardrive and it still was weird it was doing these strange lines before i put new cartridges in too. i have scanned a image of what my print outs look like.
  • Steven Luckham Oct 26, 2006
    The cartridge just slots into the cartridge holder thing so what do i need to do to fix this? or is it not fixable you said the print head has gone what do you mean by that do you not think it could be due to clogged nozzles? cuz some colour comes out but others dont its all weird.
  • Steven Luckham Dec 06, 2006
    Hi I have worked out what was wrong with my printer for some reason when i try printing from my laptop it works fine if i connect it back up too the pc its got the vertical lines again why would this be happening ive uninstalled and let xp reinstall the epson driver through plug and play but it still causes the issue both computers use xp and both have let xp install the printer driver, thank for your time.
    President:
  • 2,961 Answers
You can get this sometimes in Publisher programmes, it's a glitch, but also check cartridge alignment. If your not happy uninstal printer driver, disconnect printer and re instal driver first then re connect your printer.
Posted on Oct 25, 2006
  • andrew pester
    andrew pester Oct 25, 2006
    By the look of the image i think the head has gone on the printhead.
    If i remember this model uses a cartridge which doesnt have the actual printing part on the cartridge, it's bult into the machine.
    Just incase you want to check alignment(although it doesn't look like that)it should be in the printers tools programme with the nozzle check and clean.
  • andrew pester
    andrew pester Oct 26, 2006
    unless the cartridges you are purchasing aren't very reliable (eg not geniune epson) the cost would'nt be worth it to replace heads(the bit that puts the ink on the paper), you can buy a good epson printer now for under £50.00 Sterling
My epson stylus NX110 is printing blank pages
Printer heads clogged or cartridges are empty or defective.
Feb 10, 2014 | Epson stylus nx110 All-In-One InkJet...
The printer is only printing in two colors and only in lines going across the page. not a full print
Make sure that the ink you have, is Epson Ink.
I bought a compatible, supposely ink, and when I put it in, Colors did not come out the same. Lines and words, did not print out properly.
So I threw the ink cartridges, and bought original, Epson Ink, and Ooh-LA-LA, Printed out just fine.
Go Figure.
Good Luck
Nov 03, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Stylus Photo 820 printing magenta lines
did you clean the communication ports , where the cartridges "talk" to the printer, the ports can get covered with paper dust and erronus signals can cause the printer to activate the magenta cartridge causing your problem. reomve the cartridges and Gently clean the comm ports with a q-tip and rubbing alcohol let dry then reinstall the ink cartridges.
Jul 12, 2009 | Epson Stylus Photo 820 InkJet Printer
I get horizontal yellow lines all the way down the page with my epson stylus dx6000 all-in-one printer on all pages printed.
Not sure if the situation we're in is the same. I have a similar problem, but instead of yellow lines, it is pink lines. printer is Epson RX510. The lines are more prominent if the print quality mode used is best and if the document to be printed requires the affected color. Upon consultation with the printer technician, I was adviced that it is the print head which has a problem, and changing it is costly and the repair duration even depends on parts availability. With that, I just decided to use the printer just as is. Hope this info helps.
Jun 15, 2009 | Epson Stylus Photo 1290 InkJet Printer
Printing lines across the picture
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=90584
Q: How can I tell if the computer or the printer is causing a print quality problem? A: You can print a nozzle check pattern to determine whether the print quality problem is caused by the Epson Stylus Photo RX680 Series or some other source.
Above under FAQ
Dec 10, 2008 | Epson Stylus RX680 Color All-in-One InkJet...
Printer is Not using all the colors when printing?
if you download the ssc you can do a power clean if you dont have this tool let me no
Nov 16, 2008 | Epson Stylus CX9400 Photo Printer
Colored bars across page
I would try changing the ink cartridges and if you don't have a new set at least take out the ones you have and reseat. Also check Epson's site for new drivers. Try printing from a different program.
Mar 28, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus Color 760 InkJet Printer Logo
270 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
