V6 engine: firing order: 1 2 3 4 5 6, distributor rotates clockwise. Left bank of engine (driver's side), cylinders 2, 4, 6 (#2 at front of engine). Right bank: 1, 3, 5 (#1 at front of engine).
Inline 6 engine: firing order is 1-5-3-6-2-4. Distributor rotates clockwise.
The number one tower on the dist. cap should have a mark or numeral 1 on it. If not, turn crankshaft to top dead center of compression stroke on number one cylinder, the 0 degrees or "T" mark on the crank pulley pointer. If you are on the compression stroke (not the exhaust stroke), the rotor under the dist. cap will be pointing to the number one cylinder spark plug wire tower.
SOURCE: Need diagram for 1998 Jeep
hi, you didn't say what engine you have, I'll assume it's the 4.0 L in line 6 cylinder. Standing on the PASSENGER side of the jeep, the spark plug at the front of the engine is #1, the next is #2, and so on to #6 which is at the back (nearest the windshield).
The distributor is between you and the valve cover on the engine. Pretend the top of the distributor cap is the face of a clock.
The #1 spark plug wire goes in the cap at what would be the 6 o'clock position, (as viewed from your position standing on the passenger side, facing the side of the engine). The firing order direction is clockwise, so the 'hand' of the clock (actually the rotor in the cap) would continue to the next distributor cap plug in, which would be spark plug wire to #5 (8 o'clock position), then #3 (10 o'clock position), #6 (12 o'clock position), #2 (2 o'clock position), #4 (4 o'clock position). So all this means isi your firing order is, 1,5,3,6,2,4 If you have a different motor or any questions, let me know. Good Luck! countrycurt0
SOURCE: need wiring digram from spark plugs to distributor cap
Review the Jeep ZJ Repair Manual in the Firing Order (page 10 and 11) for 4.0L 6-cyl and 5.2L 8-cyl.
I really hope hepled with this (remember rated this help) Good luck.
SOURCE: fuse box diagram for 1995 jeep grand cherokee laredo
look on the net that is where i got mine
SOURCE: electrical circuit diagram for jeep cherokee 1995
how do i find 95 grand jeep cherokee distributor diagram
SOURCE: wiring diagram
Try this link http://autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/15/3e/8f/0900823d80153e8f.jsp
