Question about Sony Televison & Video
Grandchild scratched large tv screen with sereated knife
I do not know the specifics of the size of the tv, however, my son said it was a large flat screen tv..Sony.
Grandchild took a sereated knife to the screen..it looks as if he took a crayon and wrote on it, but the picture is still available..is it repairable.
It is not repairable..A new tv will have to be bought.
Posted on Nov 10, 2008
I have a sony tv bz21m50 it's proplm is video extra large size
If the EHT voltage is less than normal, this kind of fault can occur. An other impassibility is with capacitors. Replace all the electrolytic capacitors at it SMPS secondary out voltage points.
May 27, 2013 | Sony KV-BZ21M50 21" MultiSystem Flat...
My son scratched my screen very bad how do i fix it
Sorry u have to live with it.The very bad scratched on tv screen panel can't be repair.The only way is to replaced the whole tv screen panel and the new screen panel,will cost the same as a new tv.So it not be practical.Because the tv screen panel are limited production by the tv corporations.
Nov 16, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Picture too large for screen
It appears that on this television you can only adjust the picture size when you are using the twin picture feature. You must adjust the picture size with your other remote control. Since I do not know whether you are connected to a cable box or a satellite tv box or a blu ray player or a DVD player I cannot be very specific. On your other remote control you should had an hd zoom button, aspect, format, ratio, #, or etc. Those buttons change the picture size. The other factor determining picture size is the resolution the equipment connected to your tv is set to. This tv supports 1080i but you should also try setting the connected equipment to 720p or 480p or 480i. Also the connected equipment may be connected to your tv in two places so make sure you are on the correct selection using the tv video button on the Sony remote.
May 06, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Scratches on tv screen.
I have used clear plastic sheets and silicon tire dressing for smaller problems like this, but no idea how well it would work with a large screen TV. The westleys silicon tire shine smooths out the scratches, and you place the clear plastic sheet on top of that and work out any bubbles then tape the ends. It pretty much changes a standard screen into a glossy screen with the added benefit that you can always replace the sheet if it is damaged.
I usually get my clear plastic sheets packaged with the new LCD screens I purchase for repairs and I just keep them in storage.
Mar 12, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Need an idea
Scratches on TV screens are not good. There are no fixes or repairs to get the scratch out. Depending on the size/model of your TV, you might able to get a new screen.
Sorry to be the bearer of bad news,
Aug 26, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
42 inch poloroid lcd plasma tv
The screen will have to be replaced to service properly. Look up for the authorized service rep for service of your TV set.
Jerry G.
Apr 16, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Maxent 27" LCD Flat Screen TV
It sounds as if it has a video processing problem or the LCD panel is going bad. Can you feel the scratches? If not it is in the panel. Also it could also be the set top box or cable box if you are using one. Also try another source like a DVD player. If it is still there, then it sounds like what i stated above. Good luck and keep me posted. Guru Jay
Feb 02, 2008 | Maxent MX-27X1 27 in. HD-Ready LCD...
VS 50605 screen replaced
first of all wally heres what to look for. remove speaker grill not sure of your model. speaker grill should pop off. then you will see screws holding the large plastic screen assembly. noww if you look there might be a group of wires going up to screen,they will be atatched to small plugs unplug them, remove small screws on bottom of screen assembly, entire plastic screen assembly will first slide up then pull away put assembly flat on floor (don't scratch screen put on carpit or sort surface ) screen side down. all around plastic screen you will see brackets with screws holding them on remove top,bottom,side bracket carefully put screen back in making sure the front side of screen is down replace brackets if plastic is not damaged should screen in place.reverse order of removal. remember alittle up then screen will slide down in groves doc
Aug 13, 2006 | Mitsubishi VS-50605 50" Rear Projection...
Televison & Video Logo
109 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
