Question about RCA P52939 52" Rear Projection Television
PO VO 1.15 displayed on screen turns on with channel up button on tv, will not turn off unless unpluged from outlet remote dosent work
3 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: RCA 52" Mdl P52939, PTK195S16B
but there are two
quick things you might be able to do. If it is a PTK195 you can most
likely install the updated power supply board. If you can solder and
know safety (like discharging caps) you can update the PS chip from an
STK730-??? to an STK730-180 (IIRC). I found that simply replacing the
chip with an equivalent fails most of the time. The 180s seem to hold
up.
Posted on Dec 19, 2007
ercupa190
  • 12223 Answers
SOURCE: how can i get my rca to work
open the remote control and clean the keypad with special spray contacts cleaner from dirty, oxide, etc.Resolder the colder joint for a good contacts.
God bless you
Posted on Jul 01, 2012
I have a Sharp flat panel model LC-20SH4U. The units power LED light is red. No effect (sound or picture) when remote or on/off switch is activated. The LED light slightly blinks.
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope this may help;
Regards,
VOTIT
Aug 09, 2008 | Televison & Video
Error message on screen that says PO 1.15 V100
The error is likely to be from the satellite as the set model listed does not have that kind of error.
Nov 29, 2012 | RCA P52926 52" Rear Projection Television
When the power is turned on, the screen stays black (nothing is displayed-totally dead). Then it won't turn back off unless I unplug it. The model is DX-LCD37. It doesn't matter if I use the pannel...
Had a very similar problem with mine - not sure if this will help or not, but it seems to be doing the trick (channels scanning as I type).
I unplugged the tv for about an hour. I unplugged the cable, and all the components. Then I turned the tv on, and was able to get to the menu screen. Previously, I couldn't change channels or even power off from the buttons on the side of the unit either...
Once there, I plugged the coaxial cable directly into the side of the set, then ran the auto-scan.
I know it's not a techincal answer, and a bit strange, but as I mentioned, it seems to be working for my issue.
Nov 26, 2010 | Dynex DX-LCD37 TV
Cannot turn on or off the tv with remote,can't turn up or down vo
It sounds like either the remote is no good or the ir receiver in the TV has gone bad. try new batteries, or even a universal remote. this will help tell you if it's the TV or remote, good luck
May 31, 2010 | LG 42LG50 42 in. LCD HDTV
High school musical tv
Resetting the TV
NOTE:
1. Unplug the TV power cord from the power outlet for 4 hours.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Sep 07, 2008 | Disney Televison & Video
Tv is on but wont play
Resetting the TV
NOTE:
7. Turn on the TV.
Give the brand name and the model number..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 25, 2008 | Televison & Video
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Samsung BN59-00599A Remote Control
Picture gets hung
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Aug 17, 2008 | Fujitsu P42VHA30WS Television
Constant channel box on screen
There should be a button on the remote called display and this should turn off the channel display. If it dosent then have the remote checked and make sure its working in that function. A universalo remote wont work as well in most cases. Good Luck
Jul 02, 2006 | Sony FD Trinitron KD-36XS955 36" TV
RCA P52939 52" Rear Projection Television Logo
61 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
