Question about Samsung HT-P38 System
Speaker system When we turn the sound system on the screen shows "Protection" and it turns itself off.
  • Anonymous Dec 07, 2008
    WORKS
  • 34 Answers
This definately means that you have a positve and negative speaker wire touching somewhere. First thing to do would be to check all connections at the speakers and on back of receiver and make sure all wires are seperated. This is a common problem if two wires are touching each other. If you check all connections and they look ok and you still have same problem you need to start unhooking all wires and hook them up one at a time and turn on system. If it works with one speaker then try hooking up a second speaker wire and so on until it gives you protection message again. Basically process of elemenation. Once you says that protection message you need to replace the last wire you hook up all together as you could of damaged it when running speaker wire or it could be a defect in speaker wire.
Posted on Nov 09, 2008
"S-Protection"
I have disconnected all wires from the back of player, and it still turns off and says "s-protection". If I unplug it and plug it back in, it will work for about 30 seconds then goes off. Would that mean there is a short inside the unit itself?
Mar 16, 2014 | LG BH9230BW 1460W 9.1-Channel 3D Smart...
Technics sc eh600
Check the integrity of your speaker wire, make sure they are 'phased' (-+) properly, also check all other connections, it sounds like the protection ...
Nov 25, 2013 | Audio Players & Recorders
I have a samsung ht -tx 22 dvd home cinema system and for sometime now, the screen shows PROTECTION and it reverts to standby mode by itself.. Need help badly as sometimes it plays for 1 to 5 minutes and...
Check all your cables, connections and speakers. If they are all good, then either there is a fault on the protection circuit or the power amp has a fault on it. If the unit has a fan built into it check that is working. Sometimes the fan can get blocked up.
Sep 24, 2017 | Audio Players & Recorders
My aiwa dvd player HT-DV90 won`t stay turned, in the screen shows PROTECT and turns off ...
Check the speakers one by one, maybe one of them are damaged and make the device going on protection
Aug 26, 2011 | Aiwa HT-DV90 System
The home theatre system LG HT904TA went in to protection mode. Mean that the receiver/dvd panel shown 'protection ' on the display panel. I have try to switch off /on but the 'protection...
If you've disconnected the speakers and the fault is still showing then the fault is internal with the Amplifier and it's shutting down to protect itself from further damage.
Your only solution is to remove the cover and have a look at repairing it yourself or take it to a repair shop.
Jun 28, 2011 | LG Audio Players & Recorders
I have samsung HT-TXQ120 and when I try to turn on DVD system,on the screen shows PROTECTION ,And then turn off ,I don't understand why ? thanks
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for ntermittent shutdown.
May 25, 2011 | Samsung HT-TXQ120 Home Theater System...
When pug it in show protection on the screen and blink.
Disconnect all speaker wires at the receiver then turn it back on. If it stays on, your receiver is ok and only protecting itself from damage due to a shorted wire or speaker. Once you've determined that the receiver is ok, reconnect your speakers one by one and test by turning the receiver on. You will either find that you've fixed the problem by re-connecting neatly all speaker wires or you will find a bad wire or speaker. If you still need help, post a comment and I can help you troubleshoot further. Hope this helps
Sep 19, 2009 | Audio Players & Recorders
I have a samsung home theater system HT-X70. After 10 to 15 minutes the word protection scrolls across the screen then goodbye and finally the unit shuts itself off.
ther is dc voltage applying your speakers by amplifire itself and turn on speaker protection circuit itself.
it can be happens because
1.loose connection in amplifire board
2.faulty output section of amplifire
3.short circuit of speakers
4.error detecting circuit faulty.
if youcan open the cover and clean the circuit for dust and resolder the circuit with 30 W soldering iron cairfully.if you want the more asistence please come again
ican hlp you more.
Jan 08, 2009 | Samsung HT-WX70 Theater System
Amp keeps turning itself down - cant turn off 'protection'
yes,pls.stop plugging the system,you may harm your system if you do so,the system has it's own system analysis mode,and if there's something wrong in the circuitry,it will activate,you need the authorize service center my friend,it's a technical problem.
Dec 09, 2006 | Cambridge Audio Azur 540A Amplifier
Samsung HT-P38 System Logo
201 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
