Question about JVC KD-S580 CD Player
JVC KD-S70R The unit worked fine for a week or so. The little red light at the top left hand corner stay on and you are able to insert and inject cd's, the display also lights up for a few seconds with the time if you press the display button but then it shuts down again. Apart from that the unit stays in standby the whole time and does nothing.
  • Anonymous Dec 16, 2008
    The head unit doesn't turn on with the car any more, or at all really. Hitting display shows the time for 5 seconds and it will eject and accept a cd and then go blank. its worked for almost a year now.
    New Friend:
  • 74 Answers
You have a blown fuse there are 2 fuses for this unit yellow wire and red wire one of them has no power
Posted on Nov 28, 2008
I have a JVC KD-R80-BT it is one week old and when it s cold outside the clock stop working
I had the same issue. I found that this is normal system function for one of the three clock displays. This will only affect the large clock display. When the unit is too hot or too cold, a symbol LT will appear on the screen in the upper right corner. When LT disappears, the unit temperature is at a satisfactory level and the clock will function normally. In the manual, it says that displays is frozen until the unit heats up or cools down because scrolling would be fuzzy.
Jan 27, 2013 | JVC KD-R80BT AM/FM CD/MP3 Car Stereo...
Press and hold SEL until menu appears
Using the scan button (FWD/REV), select Clock H
Using the volume knob, set the value
Using the scan button (FWD/REV), select Clock M
Press SEL to save and exit
Jan 22, 2010 | JVC KD-G230 CD Player
There is a red lock in the top left hand corner how do you get rid of it make the tv work again
sounds like its locked parental control mode ? try useing your remote and go that setting and click on should turn green again.if it brings up something wanting a code try jvc tv does that to on one channel and i just typ in 0000 and it works fine................
Dec 08, 2009 | Televison & Video
Color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Apr 24, 2009 | JVC Arsenal KD-AR560 CD Player
JVC KD G230 CD player power trouble...
tienes q revisar voltage de entrada el de stand by y el regulador si no te sale verifica el micro procesador
Mar 07, 2009 | JVC KD-G230 CD Player
Jvc kd-pdr31
I believe You have to have the right auxillary connection to plug it in -- looks like in the lower right hand corner if you are looking directly at the unit.
Apr 17, 2008 | JVC KD-PDR30 CD Player
Power will not stay on
Sounds like you're not getting voltage on the accessory power lead. This is the red wire at the back of the deck, and it supplies power whenever the key is switched on. It's possible that your vehicle's radio fuse is blown.
Aug 11, 2007 | JVC KD-PDR30 CD Player
JVC KD-S580 CD Player Logo
248 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
