Thanks for the info, but I have another question. I get it that I need a usb hub to have both printers available to use rather than unplugging one to use the other. Thanks for the website. I found a couple different ones in a department store here for about $30 each. I'll probably pick one up on the weekend. I'm just wondering though, if when I uninstalled both drivers for both printers and only installed the laser printer, why it wouldn't print from the usb port on the back of my tower. Wouldn't the fact that I uninstalled both and only installed the laser printer "erase" what the computer thought I was using before and revert back to the original hook up of just the laser printer?
-   i need the driver for my sipix printer to work on window vista, i have the usb hub installed, but i dont know how to make the printer work. Please help-   deliziosa63
The answer is yes your PC will not look for any previous drivers to work the printer, but the USB ports on the motherboard don't work on the printer driver, they work from a usb controller, which is where the problems can stem from them not liking hardware change. Its not a software driver issue but a connection issue, i have it regular.
Did the pc say that it found new hardware, then continued to install drivers and then informed you that your hardware is installed and ready to use.(pop up on task bar)
If you put your printer into another usb port the PC would need to find the drivers again, it does not know that your printer has already been set up in another port.
But you must install both printer drivers ready for when you plug them both in(one at a time.)
I have no problem any more, it has been solved.The problem really is Samsung organization. My...
(More)
I have no problem any more, it has been solved.The problem really is Samsung organization. My printer ML-4500 was working fine with windows XP but would not work with windows7.For three days I have tried to find a driver in Samsung website,no luck.I called Samsung US on the phone and was informed that there was no compatible driver available,and was informed that I should try the internet to see if I could find one. Later my son visited me and was able to find the driver in Sansung website. I did not find it before and one of your expert informed me it was not available. As I have already said you are not well organized and I did not get any help when I needed you. Have a good day. Joseph Bucciol
Hi there My printer stops after pull the paper a little. I sent it to the techical assistance in...
(More)
Hi there My printer stops after pull the paper a little. I sent it to the techical assistance in warranty, and the printer return with the same problem. They tell me there is a problem with the tone cartridge, and the warranty dont cover it. Could some one help me ? Thank you very much Fernando Branquinho
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
