Question about GPS
I have a Garmin GPS Map 180 that has an internal memory battery problem. When the memory battery was replaced with a similar (not exact) battery the unit will not function. It sounds an alarm and displays memory battery failure. Garmin will no longer fix these units (rough translation - we want you to buy a new one).Where can I get it fixed?
  • 196 Answers
Try. radio shack for this.
Posted on Nov 09, 2008
  • mmechanics Nov 09, 2008
    Panasonic BR2032-1F2 is the same battery can also be used in garmin  GPS Map 180.
    if u have tried this have to place an order to the nearest repair center for the new battery and wait for that as it cannot be repaired.
    or the best place u can get the battery is ebay.their u will definately get the battery .
How to access maps on sd card
Same map name on internal memory and sd card can be problem.You can also try to upgrade your software with garmin web updater,but be sure that your battery is fully charged before doing an update.
Jul 27, 2014 | Garmin nuvi 1490T GPS Receiver
Gpsmap 180 firmware corrupt
It sounds like it has lost its memory battery. Usually you
would get a "memory battery low" message as it is on its
way out but you don't mention that so perhaps it has
completely failed.
The battery is rechargeable - if you leave it switched off
and loaded with a fresh set of alkalines for a few days it
may recover. If not contact Garmin as they have replaced
many memory batteries free of charge even out of warranty.
Oct 30, 2007 | Garmin GPSMAP 430 GPS Receiver
How can i get a replacement memory battery for garmin gps-75?
FDK ML621 TZ1 Battery
Garmin GPS Internal Battery
The link above has info on the battery replacement. You can do a search for the battery using the battery number.
May 29, 2014 | Garmin GPS
No map data availble
Your Garmin GPS has an internal memory or an SD-card that contains an "operating system" and "map data".The operating system is like windows or Mac OSX. It contains the menu and everything the GPS displays. The "map data" is a digital roadmap the GPS uses to calculate your route. If the map data was on a SD-card that was inserted in your GPS, it could me that you lost the SD-card. That could be the reason your GPS can't find the map data. Sometimes it happens that when people connect their GPS to a computer to update the "operating system" of the GPS something goes wrong. For example, when you disconnect your GPS from the computer while the update software is still writing data to your device, the connection gets lost and you're left with corrupt files on the GPS. It could also be a defect in the internal memory of the GPS. I suggest you try to update the operating system with a program called "Garmin Express" (just google and easy find it). You need to connect the GPS to your computer with a USB cable. Then you can perform an update. I hope it helps to solve your problem. What you could also try is to soft reset your GPS. To do that, you need to remove the silver or blue frame around the screen of the GPS (it pops off). Behind this border there is a reset button.
If the map data is completely gone, and you don't have a backup there is only one solution: Buy the latest map for your GPS online and download it to your GPS. It's expensive. In that case it's better to buy a new device in a shop. Most new devices contain Lifetime online map updates (model name nuvi -then the number - LM or LMT) (LM= Lifetime Mapupdates T= Traffic information) Then you can update your map data every three months if you want.
Nov 08, 2013 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 215 is not detecting secondary map which I have placed on sd card. What is the solution?
The map must be named "gmapsupp.img" on the SD card and not "gmapprom.img" like on the internal memory of the unit.
Sep 12, 2013 | Garmin nuvi 215 GPS Receiver
"No Map Data Available" - Garmin Nuvi 350
This is because your map file has either been deleted or corrupted and needs to be replaced. Please see this link for more info. Too much info to copy & paste here:
- Jim
Dec 12, 2008 | Garmin Nuvi 350 Car GPS Receiver
Memory Battery Died in my Garmin GPS 12XL...Can I replace it?
Wildstreak, same happened to my GPSMAP 180. Its old and no longer supported by Garmin. I did call them and they gave me the model and number of the battery (mine is a Panasonic) Also advised that units are heat sealed so I am taking mine to a local electdronics shop that also sells Garmin and have them replace the battery.
Seadrive Joe
Aug 29, 2008 | Garmin GPS
Internal Battery Low
Same problem. Remove the 8 screws, unsolder the battery from the circuit board, pry off leads, place electrical tape around edge of new battery, solder on the leads, solder leades on circuit board. Remember which side was up before soldier, close unit, you should be good to go.
Aug 14, 2008 | Garmin GPSMAP 180 GPS Receiver
Garmin 180
You need to replace the internal Battery with the Panasonic BR2032-1F2 battery. However, yes your waypoints will most likely get lost when you do this.
May 07, 2008 | Garmin GPSMAP 180 GPS Receiver
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
