Question about Honeywell Heating & Cooling
Honeywell gas valve will not hold pilot light supply. I see inside what seems to be a permanent magnet with a spring loaded keep plate. but how does the resistance of the thermocouple affect this?
  • Keith Harmsworth Nov 09, 2008
    Central heating boiler, not air conditioning
  • Keith Harmsworth Nov 15, 2008
    Thanks, I know why the safety is there, but didn't know why it wasn't working.
    I finally found the fault and have now got it working - there was a break in the coil connection inside the valve.
    The bit I don't understand is how resistance in the thermocouple could have any effect on the magnet. I now realise it is not a permanent magnet.
    The magnetism, which is quite strong, is "generated" by an increase in thermocouple resistance (from the heat of the flame of course) this holds a spring loaded plate captive to release the main gas supply.
    There is a "U" shaped peice of iron with a coil of wire wound up each leg of the U and this is connected to the thermocouple - no external power. magic ?
    Champion:
  • 254 Answers
The resistance of the thermocouple proves that there is flame present at the pilot it is a safty so that unburned fuel deposits do not occur. If your safty valve is magnetic I dont understand your question.
Posted on Nov 15, 2008
Install thermocouple in vent free gas heater
All thermocouple leads have two ends.
One end has the elongated bulb that the pilot light heats up, other end is stubby and threaded, which screws into the gas valve.
Locate valve and pilot, remove bad one, reinstall new one.
This is also the same for all gas waterheaters, ranges, and any appliance that has a steady pilot.
But, sometimes it's the valve. That requires further testing with a meter for 400 to 700 Mili-amp-hrs output or using the magnetic spring loaded solenoid from gutting out an old gas valve.
Jan 13, 2015 | Procom QL300TYLA Heater
Is there a pilot setting on my Honeywell gas valve for a Laars series 2 gas heater for my spa 175N
yes look at gas valve turn to pilot hold down for about a minute then light pilot generator keep holding button down for about 2 minutes then turn to on should stay lit if not need new pilot generator
Dec 06, 2014 | Pool & Spa
How to light a pilot
Turn the knob on the gas valve t the PILOT position. Press down on the knob so that gas can get to the pilot. Light the pilot. Keep holding down the knob till the thermocouple gets hot enough to hold the safety magnet open and keep the pilot burning. Then move the knob to the ON position. Once that is done raise your thermostat setting till the heater comes on then adjust according to you comfort and party on Amigo!
Oct 27, 2012 | Heating & Cooling
We have an atwood lp gas water heater 6 gallon g6a7 white rogers control. The pilot lights but when we turn it to on it goes out, even after holding it up to a minute. It was running fine, we thought we...
If pilot stay lit, then thermocouple is working.
If pilot will light, then you have gas. If pilot goes out when pilot button is released, then thermocouple is next suspect.
Thermocouple tip must sit in pilot flame.
The pilot light heat applied to two different metals inside thermocouple causes small current.
The current travels back to gas control valve through copper line.
If the gas valve receive this current, then a magnetic switch stays open and allows gas into the gas control valve.
The magnetic switch is on the end of the red button you push down when lighting pilot. Essentially the red button is an override to the magnetic switch.
If the gas control valve does not receive the current, then the magnetic switch does not stay open when you release the red button.
When replacing thermocouple, note that it is not screwed very tight into the gas control valve. Finger tight + 1/4 turn. If it is overtightened, then the small thermocouple current shorts out against the gas control body.
Sep 01, 2012 | Water Heaters
Why does pilot light turns on gas burner only to have it go out about 10 seconds later? 30 to 40 sec later repeats,without lighting. What is problem? once in awhile, it will light..not often. The burner...
Hello
Sounds like the thermocouple is going bad.The thermocouple is a thin tube that runs from the pilot lite to the gas valve.
What it does is it sences the heat from the pilot lite and keeps the gas valve open to allow the pilot to stay on.
This can be easily repaird by shutting off power and gas to your heater and removeing the thermocouple from the gas valve,then unclip or unscrew it from the pilot lite area.
Any plumbing supply store or home depot or lowes should have these.
Once you get a new one,install to gas valve and pilot lite area then turn on power and gas to heater and follow pilot lighting procedure,you may need to hold gas on for 60 seconds.
Here is a picture of the thermocouple so you know what to look for.
http://thermocatalytic.com/Thermocouple.JPG
http://homerepairgeek.com/wp-content/uploads/2010/12/furnace-thermocouple.jpg
Feb 10, 2011 | Honeywell Programmable Thermostat Heater
How do you turn the pilot light back on? This is an older model, probably about 10 years old or so.
Move the gas valve knob to the PILOT position and press down on the knob. You will be pressing down on a spring loaded safety magnet. Now light the pilot and keep holding down the knob till the thermocouple gets hot enough to produce electrical current and hold that spring loaded magnet in. This is your safety device. If the heat gets too hot the furnace has a fuse in line with that magnet.
When the pilot stays lit by itself without you having to hold down the button then advance the knob to the ON position. Then go to the wall thermostat and turn on the heater.
HOW IT WORKS: WILLIAMS WALL HEATER
Nov 11, 2010 | Williams 6508732 Gas Heater
Burner lites but goes out after 2 or 3 min.
the white rodgers gas control needs to be replaced;
the way it works is: the thermocouple opens the pilot gas circuit and, holds it open
when it heats up by creating a magnetic field in the gas control then: when you turn
the knob on the gas control to "on" a valve inside the gas valve opens the main gas circuit and, electricity supplied by your RV keeps it open.
the main gas coil inside the gas valve is defective and, can not hold the main gas circuit to the burner open anymore.
Jul 24, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
When letting out the button on - on- pilot goes off . what should I replace thermocoupler or the generator?
Hello
The thermocouple feels the heat of the pilot light,through a small copper line running back to the gas valve.
This lets the gas valve open enough to keep the pilot lit.
I would replace the thermocouple,also make sure your holding the dial in the pilot position for at least a minute.
Mar 22, 2010 | Honeywell Heating & Cooling
CBN30T,DESA, pilot lights, but flames out when the burner comes on.. burner stays on a few seconds and shuts off due to cold thermo-couple. pilot flame seems to jump up and disconnect from the jet, as if...
ONLY ONE OR TWO THINGS AT FAULT.YOU HAVE A BAD THERMOCOUPLE.THIS IS PROBLEM 90% OF TIME AND CHEAPEST REPAIR.IF THIS DOES NOT SOLVE PROBLEM GAS VALVE IS BAD.HOW IT WORKS:THERMOCOUPLE WHEN HEATED WITH PILOT FLAME CREATES ASMAAL ELECRTRCAL SOURCE THAT HOLDS A MGNET OPEN AFTER HOLDING THE PILOT DOWN FOR ABOUT A MIN..THEN TURN GAS VALVE TO OPEN POSITION AND MAGNET WILL HOLD GAS VALVE OPEN.IF GAS VALVE DOES NOT STAY OPEN IT USUALLY INDICATES BAD GAS VALVE
Oct 13, 2009 | Desa International GWP30T Heater
Comfort Glow Vent-free Gas Heater CGN18B
the pilot light is operated off a millivolt generator. that is the small tube directly in the pilot flame. its purpose is to generate a small dc current which is connected to the pilot valve inside the main valve. setting the control to pilot opens just the pilot gas supply. when operating normally the millivolt generator keeps a small electromagnet pulled in that keeps the pilot gas supply open. if it don't work the pilot gas supply valve closes. replace the thermocouple.
Dec 04, 2007 | Heating & Cooling
Heating & Cooling Logo
208 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
