Question about HP Wireless Optical Mouse
HP wireless mouse problem
How to shut down the HP wireless 3 button mouse as even after shuting down the laptop and removing the USB device red light keeps on blinking
    President:
  • 8,637 Answers
If it has a button on the bottom of the mouse, press and hold till it goes drk.
Hope this helps, Bud
Posted on Jan 19, 2009
I cant get the mouse to connect to my laptop
Desktop or Laptop ?What type of mouse ??...
Enable a Mouse for a Laptop
Without the ability to drag and drop and point and click, a laptop computer is merely a desk ornament.
Most laptops are manufactured with a built-in mouse in the form of a touchpad.
If the touchpad fails or if you just prefer working with a mouse, it is easy to enable a mouse for use with your laptop.
Purchase a mouse that is compatible with your laptop.
You can find compatibility information on the manufacturer's website.
If the mouse is wireless, make sure that the USB receiver is included, or purchase it separately. The mouse will not function without the receiver.
Insert the batteries in the mouse if you are installing a wireless mouse.
The battery compartment is generally located on the bottom of the mouse.
Connect the USB mouse to the USB port on the computer.
If you are using a wireless mouse, connect the USB wireless receiver to the USB port.
Turn the computer off and then on again if you are enabling a standard mouse with a wire.
This will instruct the computer to run the "new hardware" wizard, which will walk you through the installation of the mouse, and your mouse will be enabled.
Turn the wireless mouse over, and locate a small indentation with a button.
You may need to use the tip of a pencil or pen to depress this button.
Simultaneously press the button on the mouse and the small button on the USB receiver.
This will initiate communication between the mouse and the receiver.
Hold the buttons down for about 5 to 10 seconds until the light on the mouse comes on.
Test the connection by moving the mouse.
If the cursor moves, you have successfully enabled the mouse.
If not, check that you have the batteries installed.
Try pressing the buttons independently of one another.
Press the button on the receiver until the light blinks and release it.
Press the button on the bottom of the mouse until the light on the mouse is lit.
This should enable your wireless mouse.
sign up
http://ftp.pisd.edu/guide/wireless-keyboard/wireless-keyboard.pdf
Wireless Mouse to Your Computer & Laptop
Connecting a wireless mouse to your computer is a great way to reduce clutter around your workplace. Also, it is an alternative to using your laptop's directional pad.
Wireless mice work just as well as wired mice for most computing needs.
The only detail that wireless mice lack compared to wired mice is the DPI (dots per inch) and the frequency rate, which is essential to the "fast twitch" movements in gaming.
However, most people do not need highly responsive mice; therefore, wireless mice are perfect for any other computing activity other than gaming.
Insert batteries into your mouse. If your mouse is rechargeable, charge it in the docking station provided with the mouse.
Buy a wireless adapter that works with your mouse.
If your laptop is enabled with wireless technology or Bluetooth, skip to the next step.
Install the drivers for your mouse.
Reboot the computer to apply the changes.
Power on the mouse and let the computer recognize the new hardware.
If you are using a mouse that requires software to run, enable the mouse in the software that is provided to you.
http://www.sunvalleyus.com/Article/LaptopKeyboardInfo/46.html
also
Laptop computers generally have built-in pointing devices such as touch pads that you can use to navigate the operating system on the go.
However, touch pads and pointing sticks are small and generally far from ergonomic.
At home, you might like to connect a full-sized mouse for greater comfort.
Computer mice connect in a variety of ways, and you should be able to find a mouse what works with whatever peripheral ports your laptop has.
As a general rule, any mouse that works with a desktop computer also works with a laptop.Laptops use the convenient touchpad and integrated scroll mouse that allow you to use just your finger to navigate Web pages, documents and open files and programs.
Just like all other hardware, the laptop's integrated touchpad and mouse can experience errors and problems that cause you to lose functionality for a length of time.
Whether the laptop's mouse is not working because of internal errors or conflicts with another device, several "tricks" can work to restore it.
Locate the function "Fn" button on your laptop in the lower left corner of the keyboard.
Look in the keyboard's upper row (the F1 through F12 buttons) for an icon of a touchpad or computer mouse.
This keyboard button acts as the toggle switch to enable and disable the built-in mouse and touchpad function.
Press and hold the "Fn" button together with the mouse icon button.
Look for the disable/enable symbol that briefly displays on your screen.
Slide your finger over the laptop's mouse and attempt to use it as normal.
Press the Windows keyboard key if using Windows 7, type "main.cpl" in the search box and press "Enter."
Press the left arrow key to navigate over to the "Device Settings" tab.
Press the tab key to reach the "Enable" button in this section.
Press "Enter" on your keyboard. Press the tab key to reach the "Disable internal pointing device" check box.
Press the space bar to remove the check mark.
Put your finger on the touchpad, and move the pointer down to the "Apply" button.
Click "Apply" to save the settings. Close the mouse "Properties" box.
Press the keyboard "Windows" logo key to open the "Start Menu."
Press the arrow keys on your keyboard to navigate to the "Shut Down" or "Turn Off Computer" menu. Press the up or down arrow key to highlight "Restart."
Press "Enter" to restart your computer and attempt to use the laptop mouse as it should normally function.
Open the "Control Panel."
Go to the "Add and Remove" or "Uninstall" programs section.
Highlight any secondary mouse devices in the list that you have installed for your laptop, such as an external USB mouse.
Select the "Uninstall" option to remove any software and settings associated with this secondary mouse.
Restart your computer and attempt to use the built-in laptop mouse as normal.
Check to see if the mouse is working properly.
Press the keyboard's "Windows" button to open the "Start Menu."
Press the keyboard's arrow keys, "Enter" button and "Tab" to navigate to and open the "Control Panel."
Go to the "Hardware and Sound" section, and press "Enter." Navigate to "Device Manager," and press "Enter" to open it.
Find "Mice and other pointing devices from the list" and open its "Properties" dialog box.
Select the "Driver" tab and choose "Update Driver."
Allow Windows to search the Internet for drivers and to update them automatically.
Restart your computer after the drivers are updated, and use your mouse as normal.
http://www.webdevelopersnotes.com/articles/laptop_touchpad_not_working.php
Aug 11, 2013 | Computers & Internet
Wireless mouse won't work, have replace battery, rebooted laptop removed and replaced mouse connection etc. Was working fine until yesterday
Is it not working at all or is it moving erratically across the screen? If it doesn't seem to be working at all, turn off your mouse then unplug the receiver's USB cable from the laptop for about 5-10 seconds then plug it in to another USB port. It may detect a new device, just let it do the automatic installation if it asks. You should here a 'tada' or ding sound when it is plugged in. When installation is completed or about 10 seconds after you hear the sound, turn your mouse back on.
If it still doesn't work, try shutting down your laptop completely instead of just rebooting it.
If it still doesn't work after that, make sure you have a spare USB mouse available then uninstall the software for your wireless mouse or mouse/keyboard combo then reinstall it.
Mar 23, 2011 | HP Wireless Optical Mouse
I can't get my hp wireless mouse workn
The first thing to determine is whether or not you are getting a connection. Check to see if there is power on the device that is plugged into your computer. (The device which plugs in via USB). If you are not getting power to that, try a different USB port. If you are getting power to that device, follow Step 2:
The next thing to try is to look underneath the mouse. If you see a red light, it means the batteries are fine. If you don't see a red light replace the batteries. If that doesn't work, follow Step 3:
The next thing to check are the drivers on your computer. You will probably need a wired mouse to do this though. Unplug the wireless mouse, then plug in a wired one. Since I'm not sure on the model of your mouse, go to HP's website and click into the Drivers and Downloads section. Locate your mouse model number underneath the mouse or wireless transmitter, then search for the drivers. Once you have located the drivers, download them to your Desktop, but don't install them. Once they are downloaded, unplug the wired mouse from your computer, then plug in the wireless mouse and proceed to Step 4:
Before you install the drivers, go Start > Control Panel > Device Manager > Mice and Other Pointing Devices, then uninstall each mouse driver listed in here. You're doing this in case another mouse driver is conflicting with your current one. Reboot your computer. Once the computer is rebooted, go on to your Desktop and install that driver you downloaded from HP's website. Press the sync button on your wireless receiver (if there is a sync button), then try your mouse again.
Feb 18, 2011 | HP Wireless Optical Mouse
Plz help me i want connect wire less keybroad and mouse thnksvjtawale2gmail.com
There are 4 possible ways in my awareness...
Method 1: Resynchronize your device with the receiver To resynchronize the mouse or the keyboard with the receiver, follow these steps. Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put any other wireless keyboards and mouse at least 6 feet away.
  1. Press the button on the receiver, and then verify that the light on the receiver starts to blink.
    Note Some newer Microsoft devices are permanently bound to their receiver and cannot be reset. If your device does not have a button, skip to Method 2.
  2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen. Otherwise, go to the next step.
  3. Press and release the Connect Channel button on the bottom of the mouse or the keyboard.
  4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
  5. For the Wireless Notebook mouse: This issue can occur if the micro-switch on the bottom of the mouse is not released. Use a pin or a pen to try to release the button if it is depressed.
The following example shows the buttons to push to synchronize a wireless hardware device:
Receiver Bottom of the mouse: The connect channel button Different kind of receiver Collapse this imageExpand this image 838398_receiver.jpg Collapse this imageExpand this image 838398_mouse_bottom.jpg Collapse this imageExpand this image 838398_portable_receiver.jpg Method 2: Try different portsTo determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse. USB keyboard and USB mouseIf the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer. PS/2 devices Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device into the PS/2 port while the computer is running.If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations:
  • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that was included with the computer.
  • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that was included with the computer.
If you have to change your configuration, shut down the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection. PS/2 keyboard and USB mouseIf you are using a wireless mouse with a USB connector and a PS/2 keyboard, verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer. Method 3: Reinsert the batteries or install fresh batteriesBoth the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. Remove the batteries, and then insert them again. If the problem persists, install a fresh set of batteries in the device that you are having problems with. Method 4: Check for interferenceItems such as wireless routers, radios, cell phones, desktop fans, fluorescent lights, and large metal objects like computer cases and metal furniture may interfere with the signal of the keyboard. Try to keep such items away from the keyboard, and check the behavior of the keyboard.
Do not put the mouse or the receiver near any electrical devices, especially transmitters such as cordless or cellular telephones or other wireless mouse devices or receivers. A distance of at least 8 to 12 inches is recommended. Do not put the mouse or the receiver on metallic surfaces or objects, especially long metallic rails or cables. We recommend that you keep the mouse and the keyboard a minimum of 3 feet from metallic objects.
Nov 21, 2010 | Computers & Internet
I have a Hp laptop bt it is now not shuting down ie all its light on keep on glowing even on shutting down and also it makes a noise while shuting down or turning it on
remove charger first and remove battery second to try which one causing problem.
if any power source cause the problem that is mean the mainboard or power board inside failed.
good luck.
Nov 21, 2009 | Computers & Internet
I plug in my mouse to my laptop and it wont work, the bottem doesnt even turn red.. when i connect it all it says is usb device not recognized, it worked last night and tonight its not.
Try disconnecting the mouse from the usb port and reboot the unit.
Now, on your touch pad, top left blue led is let showing it is functioning. Press the center button next to the led, which will shut off the internal mouse.
Plug in your mouse to a different USB port and the unit should see the mouse.
If not and the mouse does not light up, replace the mouse.
You may have had a conflict with the internal and external mouse.
Nov 13, 2009 | HP Pavilion dv9000z Notebook
I am just unale to activate the mpouse..my
Check underneath the mouse, there should be a small button, it should be the reset switch press and hold down for 3 to 5 seconds your laptop should be able to recognize it then.
Oct 21, 2009 | HP Wireless Optical Mouse
HP 3 button optical wireless mouse
It is normal because the mouse is still picking up the "stand by" power of the motherboard.
It will very very slowly trickle away any charge you have in the laptop battery, but over such a long time you would probably not notice.
The mice on my desktop machines do the same thing, as I live in an area prone to electrical surges I shut down my machines and power strips every night and as soon as I do the laser light in the mouse goes out.
On my laptop I have a wireless optical mouse and when I finish using it, I remove the USB adapter, the USB adapter then slides into a receptical in the mouse and automatically switches the mouse off saving the mouse battery.
If it concerns you just unplug the mouse when it's not in use
Jul 28, 2008 | HP Wireless Optical Mouse
MS wireless notebook mouse 3000 not working?
A friend of mine brought me this problem with exactly the same problem. here is what I found. The small notch in usb device socket under the mouse was malfunctioning. If you press this notch you will find the mouse red light blink. If you further try pressing this notch at some point the mouse red light comes on constantly. Thats it, hold it there and try to connect first by pressing the usb device connect switch and then the mouse connect switch. The moment the connection is made the usb device stops blinking and the red light on the mouse starts blinking. Wow, it works now. Some one might just open the mouse and fix this microswtich for a permanent solution.
Jul 08, 2008 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Notebook Optical Mouse Not Connecting
After reading on Microsoft about replacing the batteries, down loading drivers and "press the button on the receiver and the connect button the receiver" - I got frustrated and almost gave it flight. Then my wife stepped in and realized that there was a green reset button on the USB connector as well. (who knew?) SO.... you press the green light (which is a button) and release it.... should blink. Then go to THE MOUSE portion and press the connect button for 5 seconds or so.... and wala...... One mouse that plays again! This ones gonna cost me! :) I hope this one works for ya!
Apr 05, 2008 | Microsoft Wireless Notebook Optical Mouse...
HP Wireless Optical Mouse Logo
232 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
