No pressure on baxi boiler gauge. Does it need water and how do i fill? Thanks
Opened pressure relief valve and back filled the boiler
Posted on Nov 22, 2008
Water pressure low on BAXi Combi 80e boiler
open bottom tap first then open top tap when water is to the leval you want turn off top tap then bottom tap.
Feb 03, 2013 | Heating & Cooling
Baxi boiler 80E low pressure on boiler how to fix it?
Silver flex hose may be the (correct) filling loop. There may be a valve at each end of it, maybe just one at one end.
Open the single valve slowly and LISTEN for the sound of water entering the system, and LOOK for signs of the pressure gauge rising.
On the dual valve version open the first, then open the second slowly as above. Close both valves when pressure is adequate. Adequate is determined by the specifics of your system, but note that more pressure DOES NOT mean better showers, etc.
It should only take a few seconds to top-up, any longer indicates a significant loss of fluid from the system.
Jan 28, 2013 | Water Heaters
Baxi duo-tec boiler - when water comes on flame roars up. When i put the heating on the flames roar for 5 minutes then die down.
is the boiler a combi if so have you checked the pressure. it needs to be at 1.5 bar 2 bar at the most . also check that the heat the boiler is producing is completeing the circuit on the heating if you have access to the pipe work there should be 2 or 3 22mm copper pipes. now turn the heating on and check which one is getting warm. the one that is is your flow and in about 2 to 3 min there should be one more pipe getting hot let me no if this is the case
Oct 27, 2012 | Universal 900MM Super Thermocouple Baxi...
How do i fix problem E119 on a baxi duotec combi 24HE - boiler won't light because of lack of pressure but I have no manual to assist me as the instructions on the boiler says.
http://www.bhl.co.uk/uploads/article1477/Baxi%20Duotec%20HE%20Combi%20Boilers%2024,28,33,40%20Installation%20Instructions.pdf top the pressure by the filling loop
Jan 23, 2011 | Water Heaters
I have a Baxi WM old boiler. Hot water only needed
there should be a switch which toggles between hot water only /// hot water + central heating /// & possible off on
Either on the boiler or on a separate timer control
Oct 19, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
Combi Boiler pressure gauge reading 0, and radiator half on!
The first thing you need to do is to put some more water into your heating system. This is usually done by allowing water from your (pressurised) domestic cold water supply to flow into the system: On older boilers, this is done with a connection (often made with a removable hose) on the pipework just outside the boiler. Newer boilers may have a built-in connection with some sort of removable link (sometimes looks like a plastic key).
Once you've got the boiler up to working pressure (typically about 1 bar - 15 psi), you should be able to bleed your upstairs radiator properly.
This may be all it takes, though the pressure excursions you're getting when you run the hot tap suggest there may be another problem. See what happens to the pressure as the boiler heats up and cools down. There really ought to be very little pressure difference between the two conditions. If you see significant changes, this usually means that the "pressure vessel" (or in hydraulic terms, system accumulaor) has lost its air charge.
The pressure vessel is a metal container inside the boiler, usually painted in red enamel. Somewhere near the top, you will find a schrader valve (like the one on a car tyre), and you can use this along with a tyre pump to replenish the air in the top of the vessel. This will reduce your pressure transients for a while, but you need to keep an eye on it. If the problem returns, you probably need to replace the pressure vessel (or clag another one into the plumbing alongside the boiler).
A.
Feb 03, 2009 | ACCO Brands Water Heaters
Baxi combi boiler 80e safty thermostat light on
baxi boiler relief valve blows off when heat is turned on when hot water is working it is fine
Oct 15, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Baxi 105 he
on the pipework near the boiler there should be a silver flexi hose connecting the two copper pipes ...this is called a filling loop there sould be taps on the filling loop turn on by moving the black plastic taps do this slow ..at the same time look at the pressure gauge on a baxi do not go over 1 bar...............
warning ..if the boiler has lost pressure where has it gone..is there any leaks anywhere..if it persist contact a engineer
Jun 06, 2008 | Heating & Cooling
Heating & Cooling Logo
132 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
