Question about HP iPAQ H1945 Pocket PC
A problem i have a ipaq hp ppc 1940 and i haven't used it for a while and i tryed to charge it but the orange flash wudn't *** on or the pocket pc and my computer won't reconise it from plz help confused
Plug in the charger - then press the soft reset button with the stylus - let sit for about a day or so...:)
Posted on Mar 09, 2009
IPAQ hp Pocket PC wont turn on!?!!
Same Problem Here I In The Dark Here I've Treid All The Other Formus I Might End Up Getting A New Charger.
Sep 23, 2009 | Compaq iPAQ H3630 Pocket PC
Which Media Player works with HP IPAQ h3660?
try this.............
Sep 15, 2009 | HP iPAQ H3650 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
i face problem on charging my HP Pocket PC 6315. when i connect my ppc to charger, after preesing power button only the frist page appear and not running ahead (welcome to T Mobile. nothing more shown here on my ppc screen.
Nov 01, 2008 | HP iPAQ h6315/h6365 Pocket PC
The factory-stock 1940, which uses Windows Mobile 2003, doesn't offer landscape mode.
You can get a 3rd party program called Nyditot Virtual Display that will let you use the 1940 in landscape mode, but I've used it before, and although it works, the problems it creates are not worth it. Besides, that program's not free.
Adobe offers a pdf reader for free that let's you read pdf files in landscape mode.
Jan 19, 2008 | HP iPAQ H1940 Pocket PC
IPAQ file store problem
You're not alone! Virtually every ipaq rx3715 gets this problem at one time or another. Unfortunately, it is a massive memory issue. Be prepared to potentially lose all of your data, including programs. My suggestion would be to back up your ipaq before you do this. I do not know if the backup retains the memory error, but what I would do is back it up, perform the fix, and then restore the data back onto the ipaq. If your file store problem is fixed, there you go! If the problem comes back upon restoring the pocket pc, then unfortunately you will lose all data and programs in order to fix the memory, and that will be a personal choice. For most of us, the ipaq simply freezes up upon entry into the file store, so consider yourself lucky that they simply do not delete.
Here is the step-by-step process of how to fix your problem.
1. Download GER and ENG ROMs (latest) from HP's support site
2. Unpack both
3. Cancel the automatic flash procedure.
4. Locate the EnterBootLoader.exe file in the folder of the unpacked GER update
5. Copy it to PPC
6. Run it from the PPC
7. Run the ROMUpdateUtility.exe file from the desktop to start flash procedure.
Then you have a German-language PPC
8. Locate the EnterBootLoader.exe file in the folder of the unpacked ENG update
9. Repeat steps 5-7 for the English update
You're done
Remember, you're not alone! We all had the same problem.
Jan 18, 2008 | HP iPAQ RX3715 Pocket PC
Lying ipaq H5550!
It's a problem with either the memory board or the button board. With my h5550, the bottom buttons started to stop working and eventualy the PPC stoped charging all together. You can find parts for it online. If all the buttons are working fine, then it's most likely the motherboard. Otherwise it should be the button board.
Dec 29, 2007 | HP iPAQ H5550 Pocket PC
Activesync problems with IPAQ 1940
 connect the cable with pc , open the active sync on ipaq then connect the cable with ipaq..if not still soft reset ur Pocket PC and reconnect.
Sep 17, 2007 | O2 Xda IIs Pocket PC
Detect camera in Hp Ipaq hw6515 PPC
I have been working on Camera cell phones and see these kinds of issues. I am afraid that your camera interface was bad and the phone main board is not recognize the connected camera. I don;t think this is a software isue when it error message said connect the camera or reset pc.. If you are not think my suggestion is correct, you may try the other way by flashing the ROM as updating the new ROM version, it may also hlep to solve this issue and if it is still not, then I am sure th efaulty is from your camera. This is an comment issue in most camera phones I have been fixed before. I hope it help.
Mar 29, 2007 | HP iPAQ hw6515 Pocket PC
HP iPAQ H1945 Pocket PC Logo
128 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
