Question about Jenn-Air JCD2389G Side by Side Refrigerator
Jenn-Air JCD2389G Side by Side... Problem: Leak
I noticed a small puddle of water on the floor in front of the frig. When I looked under the frig, it was dry. I think it is leaking from inside the freezer side. I opened the freezer and at the bottom in the back there is a grille and behind the grille, I noticed some ice. Has anyone come across this problem? Please let me know.
Thanks, Tony
  • 22 Answers
Very common blocked drain to cure unplug appliance defrost then remuve bottom panel freezer side you will find a silver tray with a drain chnnel unblock the hole that should cure it
Posted on Nov 13, 2008
Lately there is a pool of water forming under and in front of the refrigerator . what can we do. It is a side by side Jennair?
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 12, 2011 | Jenn-Air JCD2389G Side by Side...
I have a jenn air side by side and water seems to be leaking near the front left corner area at random times and when it does leak it is a slow drip.... thoughts?
Look in the freezer floor to see if you have ice built up and over flowing into the floor. If so you have a clogged drain line which is located in the freezer behind the lower basket in the litttle gap at the bottom of the back wall. If you don't have that, the water line that runs to the water in the door is located at the front left side as well and you can get to that by pulling off the bottom piece of plastic that runs along the bottom of the whole machine.
Oct 31, 2010 | Jenn-Air JCD2389G Side by Side...
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Water leaking from jenn air refrigerator side by side
check the freezer side and see if there is ice under bottom rack and floor if so you have a clogged drain,follow the floor to the back wall and the bottom of back wall panel,there is a drain there,use hair dryer to melt out and then you need a steamer or something to blow out the drain line,check it by pooring hot water in the drain you'll know if you unclogged it if the water drains through
Nov 01, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn air jcd2389ges has a sporadic water leak. I suspect that it is occurring during defrost. A clogged line? How do I access this to clean out?
Your plastic lines at the bottom left side of frig have dry rotted from the heat of the compressor. it will leak every time the water comes on to fill the internal tank. I had the same problem and I replaced mine with copper.
Oct 29, 2009 | Jenn-Air JCD2389G Side by Side...
I have a jenn air JCD2389GES. Every day I'm getting puddles of water underneath the the unit. Our ice maker is turned off (broken for the third time)but the water line is still open to dispense water. We...
The condensate drain may not be draining into the pan under the fridge or it may have a leak or could even be not connected to the condensate pan in the evaporator.
Another possibility is that your condenser might be dirty or plugged causing the suction line going to the compressor to freeze up and then thaw leaving puddles under the fridge. Clean the condenser (the coil under or behind the fridge) and it should stop.
Over stocking the freezer will cause this as well. If you cover the air return in the freezer the evaporator will freeze up and the suction line will freeze back to the compressor.
Jul 09, 2009 | Jenn-Air JCD2389G Side by Side...
My jenn air side by side has water puddling in the bottom of the freezer section. I turn off the water supply going to the icemaker etc. still puddles. Is their a condensation line that could be clogged...
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 04, 2009 | Jenn-Air JCD2389G Side by Side...
Side by side refrigerator has puddle under freezer
Check and clean door seal, chech defrost drain tube ad a cup of water and clorine into tube, Check drin pan and clean under refer.
Sep 08, 2008 | Sub-Zero 690 Side by Side Refrigerator
Jenn-Air JCD2389G Side by Side Refrigerator Logo
452 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
