Question about JVC Audio Players & Recorders
Turned on my system, but it was on very loud, it played a few secods then it sounded like it blew, now one speaker isnt doeing anything and the other just makes a thump every few seconds
    President:
  • 624 Answers
You have a serious problem with the amp circuit, you will be best served to not turn it on anymore and take it to a service center where a qualified technician can diagnose the problem with some certainty.
These units are not easy to work on and if not repaired properly they can even cause a fire or electric shock.
I have been repairing these types of units for over 18 years and highly recommend the use of a professional. If it is a good receiver, it will be worth it. You never gave the model number, so I can not just guess at what the problem may be. It can be different for every model. It also take the proper tools to be able to troubleshoot these units.
Posted on Nov 09, 2008
MY PHONE USED TO RING AND PLAY LOUD BUT NOW TOO LOW.
you just blew you phone speakers. looks like you play sounds at high volume, you will have to change the speakers to get back to the state you where in previously
May 07, 2012 | Motorola Mobility Atrix 2
My laptop was hit by a power surge through my modem, then i had a loud taping sound coming from my front speakers and now none of my speakers are working and my headphone jack does not work either.
the power surge probably did damage to your motherboard. if it only blew out your sound then you are lucky. most motherboards dont survive this well. since this is a laptop there isnt anything you can do about it. sorry
May 29, 2011 | HP Pavilion zd8000 Notebook
I turn on my subwoofer and the volume is turned down and it makes a loud buzzing sound, and its not even hooked up to the amp, just pluged in. Thank you, Joel Arntsen
You might have blown the speaker. This happens when you play things too loudly and you ruin the speaker inside. You can test this by playing something with a decent amount of bass and turned up a bit. If you hear like a "rattle" in the sound or like something isn't right in the heavy bass notes, then you definitely blew the speaker out. This isn't a tragedy. They're fixable if you bring them to a place that repairs speakers. But I would definitely test it first by hooking it up and playing a loud song with a lot of bass. Hope that helps a little! Please rate my solution!
- Frankie
May 06, 2011 | KLH ASW10-100 Subwoofer
There are no sound in my mobile of lg handset in incoming or out going calls,but when loud speaker is non the sound is on , when loud speaker is off the sound also off. please tell me what is the problem?
hi sir from last few days my lg gd510 isnot working properly thier is no sound on my speakers while playing songs while turning on loud speakers so pl;iz tell me the salution
Mar 24, 2011 | Health & Beauty
There is no sound coming from the speakers on the SC-HT900 dvd home theater sound system. It used to make a loud pop sound but then would still work. Now it does not make any sounds. The dvd will play...
May be a fuse inside blown , if it makes a loud pop that can take out a fuse, If you find one blown , replace with same type and try machine .Dont replace with higher rated fuse though , if it keeps blowing. Try using headphones and if you get sound , may be speakers.
pete
Nov 29, 2010 | Panasonic SC-HT900 System
Speakers only play cd's
Please look in your Start Menu, go to Control Panel, then into Sounds, Speech and Audio Devices. See near the left, and select Advanced Volume Control. Turn up the inputs for the other sounds that you want delivered out to those speakers. Later adjust the levels a little higher if at first the mix of the sounds is not quite loud enough from one or several of the sound sources. Also in Control Panel, Sounds, you can mute out or eliminate annoying unwanted system sounds such as sounds for minimize and maximize a computer window, and the click that occurs when the computer does Complete Navigation -which it does a lot. Go into Sounds and Audio Devices, and into the Sounds tab. Select the Windows Program event such as default beep and click pick NONE from the sound chooser scroll bar that is just below. Scroll up to NONE to eliminate that sound. Now your overall sound experience will be more pleasant, without unneeded sounds playing loudly, unexpectedly.
Feb 24, 2009 | Bose Companion 2 Computer Speakers
Constant loud muffled noise coming from the sub and speakers.
Try playing with the connection, sounds to me maybe the jack is going bad or has a shorted connection. Plug it in and out slowly to see if that's the issue.
Sep 25, 2008 | Logitech Z-5300 Computer Speakers
Crackling Speakers
It sounds to me like an impedance mis-matching problem!!!
But it does seem you have done everything correctly so I cant offer any other suggestions - sorry!!!!
Aug 01, 2008 | Pioneer VSX-D407 Receiver
Honda accord speakers
Is it all factory equipment? Perhaps he had a different system put in then uninstalled and the factory gear put back in....but not properly. Or if you meant he only had it for a day or something then perhaps he was playing it too loudly and blew the internal amplifier out. Factory decks are usually not worth repair so a new deck will be likely required. Any decent car audio shop should be able to do a few quick and dirty tests at a minimal (if any) cost.
Sep 10, 2007 | Car Audio & Video
43 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
