Question about Brother HL 2140 Laser Printer
2140 series no errors are showing, but printer will not print
  • 3 more comments
  • askdrphoto Jan 01, 2009
    I just got a new Brother HL-2140 printer ordered from Amazon and have followed directions exactly but it won't print.
    The printer printed the one and only test print, and I have installed the driver correctly, rebooted the computer, etc but there is no contact between the printer and the computer, apparently.
  • Anonymous Feb 23, 2009
    I have the same issue and everything is plugged in, turned on and off, reinstalled..it won't print
  • pintoms Mar 11, 2009
    in the device manager it has a question mark for my hl2100 series. I'm going bananas with this
  • Anonymous Mar 31, 2009
    Just installed printer drive in a Vista pc but printer will not print at all, will not print the demo.
  • Anonymous Apr 27, 2009
    Completely useless and unhelpful comment
    If such obvious actions were the solution there would be no problem
    New Friend:
  • 114 Answers
Make the printer difault. select the proper printer when you print a document.
Posted on Feb 03, 2009
  • 11 Answers
SOURCE: Brother 2140 Printer Problem
It is most likly not linked to word. Word is likly sending the prints to the wrong, obsloete or wrong copy of the printer.
When printing check to see where the doc is being sent to print.
Then go to printers to see which printer is your 2140 active and ofcourse do a test print. If the test print is good this is the correct link to your printer.
Posted on Sep 09, 2009
xptareq2000
  • 1447 Answers
SOURCE: HL 2140 page printing all black
Dear sir, I know what is problem? your toner cartridge is demage please change it also you re-install your old toner then quickly take a decission
Thanks
xptareq2000
wiz
all the best
Posted on Oct 30, 2009
komguy
  • 2306 Answers
SOURCE: for the HL-2140 Brother printer, the red error
Too many things can cause that, you remove the drum and run the blue tab back and forth to clean the corona about 20 times, the fuser may not be heating and you need a new fuser, Feel for heat in the back door or at the exit, If the drum is used up you open the front door and press go until the lights flash to reset. Make sure the paper tray is fully inserted, this one is picky. You may need a shop to diagnose.
Posted on Feb 01, 2010
Testimonial: "Thank you komguy, I posted the solution to the problem we were having, and we appreciate your willingness and time to share your expertise! "
Patzky
  • 240 Answers
SOURCE: Printer is on but will not print.
Hello ,
First, please make sure there is no error message displayed on the LCD screen of the printer
Now we will check the status of your printer in the printers menu in the control panel.
The printer’s status should be set to “ready”
If the printer is “paused” simply clear the print queue, right click on the printer and select “resume printing”.
If the printer says “offline”, follow these steps.
  1. Clear the printer queue
  2. Shut down the computer
  3. Unplug the USB cable from your computer and your printer
  4. Unplug the power cable from the printer and wait 15 seconds
  5. Plug the USB cable back into the printer and the computer.
  6. Plug the printer’s power cable back in.
  7. Turn your computer back on.
Your printer status should be back to ready now and you are able to print.
Thanks,
Pat
Posted on Mar 29, 2010
  • 14 Answers
SOURCE: We have a Brother HL
This machine has a separate drum and toner cartridge. Replacing the toner does not reset the drum light. Double check that the light on is, in fact, the drum light, and if it is, replace the drum unit. This should resolve your problem.
In order to replace the drum unit, do this: 1) With the printer on and the drum light blinking, open the front cover. 2) Press and hold the Go button for about 4 seconds until all the LEDs light up. Once all LEDs light up, release the Go button. 3) Pull the print assembly out of the machine. 4) Push down the green lock lever to take the toner cartridge out of the drum unit. 5) Put the toner cartridge into the new drum unit. 6) Reinsert the print assembly into the machine. 7) Close the front cover and verify that the lights turn off.
It is theoretically possible that you could reset the counter without actually changing the drum by simply skipping steps 3-6 above, but I have never tried it before and Brother may be checking a chip on the drum unit to verify that it is, in fact, a new drum unit. If they are, you will have to actually replace the unit to make the light go off. I would strongly recommend against resetting the counter without actually changing the drum though, as your print quality will degrade and the machine may start to dump toner into the inside creating a rather large mess and a hefty repair bill.
Posted on Feb 28, 2011
I need free support to empty memory of brother HL-2140 printer
This error occurs when your printer is dealing with a particually complicated print job and cannot process it all. Try to reduce the complexity of your document or cut the print resolution. It may be worth trying to print the document in several parts if at all possible.
I hope this helps.
Dec 27, 2012 | Brother HL 2140 Laser Printer
I don't know? Each time a send a document to be printed in the job queue it shows error
Try switching the printer off & then switching it back on. If it doesnt work, re-install the printer drivers.
Aug 11, 2012 | Brother HL 2140 Laser Printer
I HAVE HL 2140 PRINTER. INSTALLED NEW TONER BUT NOT PRINTING GETTING WITH DRUM ERROR
It is possible that the drum needs replacing.
Print a lifetime status page, and see if it says "drum 0%". If so, replace the drum and RESET the counters by using the reset button combination.
Mar 14, 2011 | Brother HL 2140 Laser Printer
If im going to print my document the selection for printer HL - 2140 series 2 was lost and replace by the printer generic how can I reset the printer bask to HL - 2140 inorder to activate?
Brother HL - 2140 Drivers
Visit the above link from Brother Official Support. Select the Operating System and download the drivers. After in stalling the drivers, go to the Control Pannel - Printers, and set HL-2140 as default printer.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 24, 2011 | Office Equipment & Supplies
How can I check the count of pages printed in my brother hl-2140 printer ?
Turn the printer off then on, wait a few secondes then press the GO button 3 times quickly.
The printer settings will print. It will show you how many pages have been printed as well as number of paper jams and errors etc.
Jun 11, 2010 | Brother HL 2140 Laser Printer
Get error light when trying to print labels - HL 2140
The driver should pop up a error message. Possibly is due to clean corona wire. Slide the blue lever several times across (at the drum unit).
Dec 10, 2009 | Brother HL 2140 Laser Printer
Thanks
xptareq2000
wiz
all the best
Oct 02, 2009 | Brother HL 1440 Laser Printer
Brother HL-2140 Error light is flashing
Try to unplug the power from the print, wait 1 minute then plug back in.
This may remove the error.
Sep 26, 2009 | Brother HL 2140 Laser Printer
Brother HL-2140 won't print from Firefox (or IE)
am not very sure but i think u should try go to printers and faxes through control panel open it and right click on your printer and select print on line
Jul 17, 2009 | Brother HL 2140 Laser Printer
Dec 19, 2008 | Brother HL 2140 Laser Printer
Brother HL 2140 Laser Printer Logo
227 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
