Question about Hotpoint Washing Machines
I need to replace drum bearings on my hoypoint BWD129 washer/dryer
  • 196 Answers
Hotpoint cannot obtain bearing or a rear drum case (apparently its easier to replace the rear drum and bearing than risk damaging the original drum - makes sense I suppose).
Posted on Nov 09, 2008
  • mmechanics Nov 09, 2008
    it cost roughly the same to change a full drum assembly as it did to change the
    inner bearing .and will be  much less time consuming
    still u want to change the bearings this is the procedure
    its a long job.
    first remove the top
    then the front control panel.
    disconnect any
    wires connected to the circuit board.
    then remove the front panel with the door intact. to do this you
    must unscrew the the screws in the top and bottom and remove the screws for the
    door inter lock as well as undue the door gasket from the panel.
    Then you got to remove the concrete weights.
    and pull the pegs in the legs from the drum side.
    Then you got to dissconect the drainage at the bottom of the
    drum from the pump
    remove the wires from the solenoid and
    disconnect the pressure switch from the small plastic tube.
    undue the tubing from the soap draw to the
    remove the clips near the springs.
    undue the front metal panel which the board was connected to and
    remove the drum.
    rate the solution if it helps u.
    feel free for further assistance.
Why is my LG TROMM frontloader dryer making a loud noise when running?
If the washer is making a loud noise the rear drum with bearing might need to be replaced. On this washer the bearing might not be sold separately, the entire rear drum might have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Sep 02, 2014 | LG 4925ER1015B 4924ER1010 Used Frontload...
Hi Gene, I have an Electrolux FEX831C30 stacked washer and dryer. the drum in the dryer has completely come loose and has dropped to the bottom of the dryer cabinet. there were two screws in the drum. what...
Good Morning Brian,
The reason the drum has fallen free from the rear is a defective rear drum bearing and that drum bearing that has sheared itself off of the bearing repair that dryer ya would need to replace the bearing kit its part number 5303281153 and would be in stock at your local applince parts store or online at,,,, or
Before replacing the drum the drum bearing you should also inspect the heat element since when the bearing shears off its not that uncommon for the drum to fall onto the heater shroud and also break the heat element
While this Youtube video i have included the link to shows how to replace the drum bearing in a full siz e free standing (not stacked laundry center) dryer the process of how to replace the rear drum beaqring is exactly the same and that video should help ya
Good luck,i hope ya find it very simple to replace that bearing,
Jan 31, 2012 | Washing Machines
Dryer is squeaking while in operation
Rear drum bearing may need lubrication or replacement. This bearing is located on the back of the drum and requires taking the washer housing apart to get to it. They sell a high temperature lubricant if that is all that is needed, but a small bit of automotive grease or bearing oil will work well. You may have to buy bearing replacement parts ie a drum rear bearing and post kit or a bearing replacement kit. You will need better than average skills to do this yourself. As soon as you take off the front panel the drum will have no support and will drop forward. Try not to let the drum belt to become to loose or the belt retention wheel may become disengaged and the belt will fall off. Make sure you unplug the dryer before taking ANYTHING apart.
Jan 14, 2010 | GE Dryers
I have a Hotpoint BWd129 washer/dryer. When I
I have a similar Hotpoint model to this, that does something very similar now and again, usually when trying to set a delayed start.
The only way I have found to "fix" it is to turn the machine off for at least 5 minutes, and then try again.
Hope this helps.
Jan 13, 2010 | Zanussi WJD1257W Front Load Washer
My Hotpoint BWD129 washer/dryer has got noisier and noisier during the spin cycles. It is now so loud it is unbearable to be in the same room as it and it rattles anything off the worktop nearby. Any...
This is most likely the drum bearings failing.
Drum bearings normally last a long time (10 years or more isnt unusual), but quite often drum bearing failure is caused by a faulty drum shaft seal allowing a small amount of water through and in to the bearings. The bearings then start to rust and this accelertes how quickly they deteriorate.
Replacing a drum bearing requires well above average DIY skills, so unless you feel you can do it, can get hold of a tech manual, and can find a supplier for the bearings, it's time to get a quote from an engineer.
Nov 13, 2009 | Washing Machines
We have a washer dryer hotpoint bwd129. Can you
a washer dryer has a different approach to cleaning fluff. It has an internal flushing system.. only do routine check on pump filter.
Oct 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
Drum paddles keep falling out (Hotpoint BWD129 washer/dryer)
I had this problem, and I was advised by the guy who has apparently 'replaced hundreds of these bloody things on this housing estate' to never buy this machine because 'its cheap and ****'
However, if you bend the long central tab ,the one that looks like it does bugger all, upwards into the drum (carefully though, only bend it a little) this will increase the tab tension, and your lifters should last for over six months instead of the previous couple of washes mine was doing.
As for the comment on washing trainers, I put a single towel in my machine and the lifters broke...
Jul 17, 2009 | Washing Machines
Rear drum bearing
When it is like that you usually need to replace the drum bearing.
Ifthe tub recently started making a lot of noise, and you can feel thatthe bearing had too much play when spinning by hand, that means thatthe drum bearing needed to be replaced.
You can find the replacement part and the schematics here.
See also :
Mar 07, 2009 | Hotpoint NWXR473EV Dryer
Please provide more details about your appliance. What brand and the age.
Nov 06, 2008 | Hotpoint WD52 Front Load Washer / Dryer
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
Washing Machines Logo
59 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
