Question about Canon imageRUNNER 3300i Printer
Canon 3300i prints / process very slow
- the machine is slow when more users shoot images for print can I increase the ram size from 126mb where is it available with the necessary software
  • pacchi Apr 22, 2009
    i sir
    how ru , this is prashanth kumar from gurgaon
    i also have the same problem can u pls solve this problem
    bye,,,,,,,,,,,,,,,,,,,,,,,,,,,,
  • 35 Answers
These machines can print slowly for a varity of reasons. First and foremost is using the incorrect driver. The correct driver can be downloaded here:
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2275&modelid=6349
Also slow printing can be a symtom of a hard drive about to fail (e602 codes).
Fastest printing speeds can be achieved using the following basic assumptions:
1) The copier is printing thru a standard cat5 cable; not thru the parallel port.
2) The network the copier is on is healthy and operating normally.
3) The network settings on the copier are configured correctly.
I am a Canon trained authorized tech on these machines and have been working in the field on the ImageRunner 3300 series since their release. I'm not sure if a ram upgrade is available but I haven't installed one in the six plus years of servicing this machine to fix a slow print problem.
Posted on Nov 09, 2008
HP designjet 500 printing void areas
Increase RAM size(64 or 128MB), your print sizes are more...
Jul 25, 2012 | HP DesignJet 500ps (42 in.) InkJet Printer
Acribat reader ir 3300 canon printer wery slowprint what is solution
Removing and reinstalling the printer driver will fix most issues such as this.
But if you are finding its just slow for PDF files read on.
If we break down the actual issue you will find that its not so much the actual printing part of the process that is slow, its actually the spooling/converting the document to the printer that takes the time.
Does your printer support PostScript printing ? (PostScript is a printing & imaging standard used by many printers) To find out if your printer does indeed support this either refer to your manufacturers documentation or perform a test page and look to see if you have a PostScript enabled option.
If your printer does support PostScript, make sure you are using its PostScript printer driver, most of the time we generally use PCL drivers, so simply change this.
Firstly we can force PDF files to be printed as graphics as opposed to text, to do this launch your chosen PDF viewer, select Print > Advanced > Print as image
This can also help to increase just about any slow PDF printing issues as it means that a soft font does not have to be created as the file is directly converted to a graphic and then printed as such.
Lower the print resolution (this can be changed from both the Windows print settings and from the printer itself if it has a LCD type panel) If we lower the print resolution most of the time the difference is very small, but it can reduce the actual file print size of the document by up to 300%, which can greatly decrease printing times, especially if your pc or printer does not have lots of memory (RAM)
Make sure you are using the very latest version of any print drivers or your chosen PDF printing program, normally Adobe Acrobat, as this will provide the most stable and efficient platform.
If the printer only has a small amount of memory if possible add more, if possible install a Post Script SI MM.
Feb 11, 2011 | Canon Ic2300N Printer
Large paper printing
12 x 18 is the largest size paper that can be used on this copier. If anything larger is used the machine will jam. The copier uses a series of paper sensors to track and time the paper throughout the printing process. The max is 18 inches anything over that cuase the machine to jam.
Apr 14, 2010 | Canon imageRUNNER C3220 Color Copier
Printing very slow its take time to print & its spooling long time
Increase the print spooler can help as does more RAM, also by using the properties panel and set prints to "Draft" or "Fast" etc, or print low resolution.
http://www.americanchronicle.com/articles/view/132224
Mar 15, 2010 | Canon LASER SHOT LBP-2900 Printer
What is the most likely reason for my Powershot G10 shooting at only 180ppi? Thanks.
You have it set to RAW for TIFF
First of all, I am assuming that when you say ppi you mean Pixels per
inch. If you take 2272 and divide that by picture size of 10", you
will be printing at about 227 ppi. PPI has to do with the printed
size. When printing in Photo shop, go to Image Size. Uncheck
"constrain proportions", and "resample image". When you enter the doc
size you will see the ppi it will print at.
ppi is not an intrinsic property of a digicam image. All cameras
output a default image size (where??--in the EXIF data?). which then
sets a ppi value.
What counts going in to Photoshop is the filesize in pixels. You can
set any print size you want.
I generally print at 250 - 300 ppi, but you can get pretty good
results down to 150. Upsampling will smooth out jaggies but will not
increase resolution.
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Canon PowerShot G10 Digital Camera
Connecting to Linksys as Router for Canon Image Runner 3300I
You can connect by using a hub. Then wire the hub to the machine and from hub to the stand alone pc. Still you have ot do some pc configuration to make the system running.
May 22, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon 5D resolution question
The 5D has a 12.8 mega pixel sensor.
2 x 4 ft. is 24 x 48 inches, so you have to cover 1152 sq. inches using 12.5 million pixels.
Spreading 12.5 million pixels over 1152 sq. inches means 10,850 pixels per sq. inch. Taking the square root gives you a maximium resolution of 104 pixels per inch (or 'dpi')
Photoshop will allow you to increase the resolution by a process known as 'interpolation' .. increasing to 300 dpi using Photoshop before printing will give a better result.
NB. Depending on your printing process, you may end up dealing with files up to 500Mb in size ....
Mar 12, 2008 | Canon EOS-5D Digital Camera
Error Code description
The Canon is coming on with a code E602-0003 can somebody please help it is only 9 months old and the company we bought it from is out of bussiness. Please email me @ reception@biscayneroofing.com
Thanks
Madlyn
Feb 25, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Scanner begins to hang.
Increase the size of the virtual memory or add RAM memory to computer. Check the Technical Support team at Canon also
May 25, 2007 | Canon DR-9080C Path-Through Scanner
Canon imageRUNNER 3300i Printer Logo
244 people viewed this question
old marine
old marine
