Question about Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel Smart Drive burning mells
Smells like burnt rubber everything still functional just smells now? Help
  • Anonymous Feb 15, 2008
    I have had the same problem with my washer for a while now. It started out as a burnt rubber smell...and now my washer will only spin cycle 1/4 loads! I have to do full wash loads and then take out 3/4 of the load and spin 1/4 at a time!!! It is So annoying!
Try: http://usa.fisherpaykel.com/global/customer-care/trouble-shooting/washing-machines.cfm?CFID=5795181&CFTOKEN=46306735
Posted on Jan 15, 2007
SOURCE:
Hello I have a Fisher and paykel 7.5g smart drive excellence washing machine it doesn't spin and I can smell something burning.thanku Kelly
Has it drained the water out. It will not spin until completely empty. If it is not draining then Iwould say the burning smell is the drain pump overheating. Do not try to run it like that as the drain pump will short out the main control board eventually. Bail the water out by hand, tip the machine back against the wall and check the pump on the front right side of bowl. Replace the pump.
Jan 04, 2017 | Fisher and Paykel Washing Machines
What could cause the engine to buzz & smell like burnt rubber inside the car
check for failing drive belts and check for a pulley that is running hot or reluctant to spin freely
Aug 06, 2014 | 1998 Toyota Camry
My car is hard to turn, it makes an awful noise and is smoking, it smells like burnt rubber, if i continue to drive it what will happen
Hi Debbie,
Not sure with out looking at it, But from what you posted if hard to turn
sounds like your power steering punp aint working , ant if smoking and smells like burnt rubber sounds like pumps locked up, (pully not turning) and if so continuing to drive it could leave you on side of road if it runs a cerpintine belt , that kind of belt runs every thing and if breaks water pump stops flowing water motor will over heat, you should realy have someone look at that for you.
Feb 05, 2014 | Dodge Cars & Trucks
When i turn the wheel my car makes a loud noise and smokes, it smells like burnt rubber, is it safe to drive it
Sounds like the power steering pump is locking up and the belt is slipping. Get it checked out before you drive it.
2001 ford escape has horrible rubber smell and bad noise
Remove the drive belt on the alternator and see if you can spin the pulley freely. Check for bearing noise or knocks in the alternator . If it is hard to turn then replace the alternator . While the belt is off check all other units and pulleys to see if they turn freely. Now check the drive belt and smell it If it smells of burnt rubber then replace it as it is what the smell is all about.
Feb 03, 2014 | Cars & Trucks
Fisher & paykel smart drive 9 mw059au no power
Most of the faults are pump related.
check the Ohms reading on pump should be 33- 35
If readings are less change your pump.
Jul 28, 2012 | Fisher and Paykel Washing Machines
I have a fisher paykel GWL10 washing machine. It shuts off while
At this stage i can suggest that the inlet valve may be faulty & giving off this burning smell.open the control box & see if one of the 2 inlet valves look distorted or brown or burnt looking.I'm wondering if it's not filling very fast also,this could also be an indication of the valve.
Jun 03, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher and Paykel GWL11 Top Load Washer Logo
793 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
