Question about GE Nautilus 24" Built-in Dishwasher
Leaking dishwasher GE NAutilus dishwasher is leaking in the front. took panels of. dont see leak today but it is leaking. Should we change gaskets rubber seal? installed in 2002
I had a ge that leaked in front, needed to replace rubber door gasket....
Posted on Nov 11, 2008
Dishwasher leaks from the bottom of the door
Hi, if it is leaking around/under the door, it must be the seal around the door. Check to see if the seal needs to be pushed in somewhere or is damaged..
Try running the cycle with no dishes in the washer and see if it leaks, it sounds like a gasket in the door to me and you can also check hose by removing the front panel on floor and check there....
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and re tighten the screw. Test the door and readjust the latch if necessary.
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Jun 26, 2011 | GE Nautilus 24" Built-in Dishwasher
Leaking aroumd the door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
,,n
Jul 28, 2010 | GE Nautilus 24" Built-in Dishwasher
Ge nautilus is leaking from the bottom of the door
Leaking Dishwasher
heatman101
kkm
Jul 25, 2010 | GE Nautilus 24" Built-in Dishwasher
GE DISHWASHER LEAKS AT LEFT CORNER
Have the same dishwasher and happens sometimes to mine when the door doesn't close properly because it is hitting the cabinet front. Try pulling up and forward from the bottom of the door when it is closed. if the bottom comes forward this could make the difference and stop the leak.
Jan 25, 2009 | GE Nautilus 24" Built-in Dishwasher
My dishwasher is leaking from the conors and sides
I replaced these black corner gaskets and it still leaked.....GOOD LUCK!
Nov 03, 2008 | GE Nautilus 24" Built-in Dishwasher
Leak from a black module, where an arm connects
if your dishwasher leaks check out this: Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Oct 11, 2008 | GE Nautilus 24" Built-in Dishwasher
Ge nautilus leak left side
If your dishwasher leaks, check these: Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
  • Lower rack
  • Spray arm
  • Spray arm support
Oct 05, 2008 | GE Nautilus 24" Built-in Dishwasher
Leaking from the front ?
Hello Kathy J...
It sounds as if you want reassurance that you should replace your dishwasher.. The costs associated with replacing the racks themselves and the gasket on the door ( depending on who does it) might justify the purchase of a replacement model.. Plus newer models are more energy efficient that the older ones.. 7 years of use is a fairly long time so you've gotten your money out of it... I always use this litmus test to validate the purchase.. if the cost to repair is close to or exceeds the cost to replace, then replacement makes sense.. Very subjective indeed.. hope you make the right choice.. :-)
Sep 22, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
648 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
