Question about Maytag Performa PAV2200
Fills but does not wash
Hi.
My dishwasher fills and then immediately drains instead of doing the wash cycle. after draining, it hums until the next fill cycle then it fills and immediately drains without washing the dishes.
  • 4 Answers
Hi!
That happens when for some reason any of the two drain/spin cycles are interrupted. Try this:
have the washer empty, then set the machine to run the last cycle to the end of it, when you usually
lift the cover to take out the clothes, that ought to do it, I had the same problem when diagnosing a
timer problem.
Posted on Nov 12, 2008
How do I fix my Danby Dishwasher? It fills with water then immediately drains.
Most likely the flood switch is triggered. This causes the pump to operate as soon as you start it. Check if the float at the base comes up when you press it by hand. If not the float spring might be stuck and pressing the flood switch underneath.
Sep 01, 2014 | Danby DDW1809W Builtin Dishwasher
Fdb126rbs2 fills and drains fine but does not
DO YOU HEAR THE MOTOR START OR HUM AFTER THE WATER FILLS? IF IT RUNS CLEAN YOUR FILTER AROUND THE BOTTOM OF THE LOWER SPRAY ARM INSIDE. LET ME KNOW IF YOU HAVE MORE INFO.
Apr 25, 2010 | Frigidaire 24 in. FDB126RB Built-in...
My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Jul 15, 2009 | Washing Machines
WATER ONLY FILLS 1ST TIME ON ANY CYCLE
Hi, After the first cycle, and after it drains/spins, does it start agitating when the next load of water is suppose to be filling?
Please let me know so I can assist you further. Sounds like the pressure hoe from the tub to the water level switch is plugged.
Thanks
Vic
May 17, 2009 | Maytag 24 in. MDB4100 Built-in Dishwasher
My carlton dishwasher fill and drains but does not wash
sounds as though the wash motor/pump is jammed or has seized therefore no wash.
Mar 16, 2009 | Maytag 24 in. MDBH965AW Built-in...
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Fills, doesn't pump to sprayer, drains on drain only cycle
Sounds like there is still something in the pump. I am 99% certain this unit has a reversable motor.
Jan 26, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
Zanussi DW907 Dishwasher stops early in cycle
the heater relay may have gone on the pcb or you may have a stat/wiring fault in the heater circuit.
Feb 15, 2008 | Dishwashers
Washing Machines Logo
188 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
