Question about Canon MX300 Office All-In-One Printer
Uneven paper feed
Pulls paper to the right and jams. My son had it for college and dropped a toothbrush into it! Is the only solution a take apart? How is that done?
  • chris_looney Nov 09, 2008
    Problem solved. I followed the advice of others and turned it upside down and shook it while tapping the sides and an object my son identified as the buckle of his watch band fell out. I put in a sheet of paper and it worked. I printed two test pages, no problems.
    Thanks!
I sprayed the roller with wd-40 and tried copying to use paper to remove the excess lubricant, after it sat for 2 days it worked fine again. luckily i didnt have money at the time or i would've bought a new one.
Posted on Dec 02, 2008
Paper pulls to right side and then jams it all started when paper jam i pulled it out and ever since then when loading paper it pulls to the right and then jams
Try running a good sized thickness paper thru it to clear out the cutters.
Sometimes when they jam some residual paper is left in the space between the cutter wheels and causes the paper to feed askew...
I use the cover from old phone books.
Sep 29, 2011 | Office Equipment & Supplies
Paper feeds crooked then jams?Used less paper different paper it just pulls the paper in unevenly the jams. Help
Check feed roller for contamination, fan the paper to seperate sheets and then make sure that you are using paper of the following standard:
Paper Type Thickness Weight Single sheets
(plain paper) 0.003 to 0.004 inch
(0.08 to 0.11 mm) 17 to 24 lb
(64 to 90 g/m²)
Make sure you are using paper supports and feed guides.
Apr 09, 2010 | Epson Stylus CX9400 Photo Printer
My MP470 Pixma won't feed paper, it pulls right
Based on instructions from your website I pushed a letter sized piece of thin cardboard backwards through the paper feed rollers then shook the printer while holding it upside down. A Q tip fell out, problem solved.
Jul 19, 2009 | Canon PIXMA MP470 All-in-One Printer
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
When trying to print paper pulls to the right and jams
try feeding the paper first, mine pulls to the right also, but if I hold it when is jerks, sometimes it will not jam
Dec 02, 2008 | Lexmark X1240 All-In-One InkJet Printer
Paper feeds into printer uneven
check for anything obstructing the path of the paper..usually something very tiny! and clean the rollers with toothbrush & water.
Nov 29, 2008 | Lexmark X2500 All-In-One Printer
Paper pulling
Be sure your paper guides are tight against the paper. If so, then clean the feed wheels with a damp cloth (just water). If this helps temporarily, you might need to replace the feed wheels.
Jul 28, 2008 | Lexmark X75 All-In-One InkJet Printer
Paper jamming and feeding unevenly
I have the exact same problem. Until last night it worked perfectly, and when it ran out of paper, I put more papers in the back of the printer correctly and since then it won't print, it pulls paper to the right and the paper jams. I tooked the printer to the service and they say that I'm lucky that the warranty did not expired yet, cause the problem is a "manufacturing mistake", and that they will take it to the Canon service.
I realy hope they will do the job. I'm expecting to repair be done till tomorow.
Apr 27, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon MX300 Office All-In-One Printer Logo
160 people viewed this question
old marine
old marine
