Firstly it sounds as if the drivers aren't loading properly, right click on your drive (right click my computer> properties> hardware> device manager). Look for your external drive, rightclick and click update driver and force it to look in your cd for driver files. Secondly make sure you are connecting to a USB2 port, as it may not recognise the hardrive.
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Hope this helps.
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive that is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
This should get you to see your external. If you don
Using Disk Management Utility
Disk management utility will help you see all the drives that are connected to your computer, including internal hard drives, CD or DVD Drives, and removable storage like USB sticks and external hard drives. Using this utility, you can check for attached drives that are not visible in windows when attached to your computer. You can also format drives, change drive letters, mark a partition as active and delete partitions. A word on caution about using the Disk Management Utility: This utility can cause destruction of data. If you are not sure of what you are looking at and uncomfortable with using this utility you should consult with an advanced user before making any changes to drives using this utility.
A menu will open
Chose "Manage"
The Computer Management window is broken down into 3 sections. The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
A drive this is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken.
I just got two of the Plumax 3.5" PM-350U2-PCS(B) external enclosures. Neither work with two different EIDE hard drives plugged into two different computers (both equipped with with USB 2 ports). I tried using two different USB cables. Both computer are running Windows XP Pro SP2. The light comes on, the fan comes on, the drive spins up but the drive is not recognized in Windows XP PRO SP2. I did not load any drivers. The manual was silent as to jumpers so I tried master, slave and cable select without joy. I see on this websitehttp://www.chipcatalog.com/Cypress/CY7C6...
that the chipset is supposed to work with the drive set to either master or slave.
I have 5 other external enclosures - they all work.
Any ideas why these don't? Could I have received two defective ones, or am I doing something wrong?
