Question about Maxtor Hard Drive
Maxtor slave settings to recover data
I have two E- machines, T1600 that the mother board is bad and I want to install the hard drive from it into my other computer ( T-3306 ) to recover some data. The hard drive I took from the T1600 is a Maxtor DiamondMax Plus 8 and from what I can find, it looks like I can install this into my computer as a slave. If I do this, can I recover data from it?
Thanks, Steve
  • 63 Answers
Leave your original drive in your PC set as master, set the T1600 to slave
Open your desktop, click my computer and click C drive, reduce the window so you can slide it to one side, click my computer again and then click G drive if that is what the slave is called. Make a new directory in C drive and give it a name, Drag your files over and drop them into the directory.
Posted on Nov 21, 2008
What settings in the bios with maxtor as slve and quantom fireball as master
There are no settings in the BIOS for setting up master ans slave drives.
The hard drives have jumpers for configuring master and Slave drives.
If your hard drives are IDE/PATA hard drives and you intend to install these drives on the same IDE cable then you can set the jumper on Quantum drive as Master and the Maxtor on Slave.
I suggest that you install the Quantum as master on the 1st IDE cable and the Maxtor as Master on the 2nd IDE cable for maximum data transfer rate between the two hard drived.
Any other devices that are connected to these IDE cables will need to be jumpered as Slave devices.
Mar 28, 2012 | Gateway Computers & Internet
I got a maxtor ide harddisk which was already partitioned, i tried to format one partition for installing windows, but seems thare were bad sectors i tried to format all but it was not possible. Now the...
When a hard disk has bad sectors, the magnetic layer is worn out and the number of bad sectors will increase. If you keep using this hard disk you risk losing your data. This hard drive cannot be repaired, throw it away and get a new one.
Jun 25, 2011 | Computers & Internet
How the jumper setting is done for maxtor n256j50
If this is an IDE/PATA hard drive then the jumper settings are marked on the circuit board.
MA = master
SL = slave
CS = cable select
If this hard drive is the one installed on the Primary IDE controller the the jumper has to be set to Master. If it won't boot up then the jumper needs to be set to Cable select.
If this hard drive is a second hard drive and is connected to the 2nd connector on the IDE data cable that is connected to the primary IDE controller then the jumper must be set to Slave.
If this hard drive is a second hard drive and is connected to the secondary IDE controller and there is no other drive on the IDE data cable other than this hard disk the the jumper can be set to either Master or Slave.
If there is a CD drive on this cable too then the drives on this data cable then the jumpers on each drive must be set differently, they cannot be set the same jumper setting.
Feb 09, 2011 | Maxtor Hard Drive
External maxtor isn't recognized on XP
Since you have important files on this drive, do not waste a lot of time with troubleshooting. If your drive is about to go out, you can put it over the edge that way and kill it.
Just to be sure, I would plug the drive into 1 other computer just to make sure. If you get the same thing, the problem is definently with the Hard Drive.
If this is the situation, I would take off the outer case to reveal the regular hard drive inside. You can hook this hard drive up to your computer as a slave and copy the files off. If your computer will not read the drive as a slave, and you have double checked the jumper settings and cable position.....you can try a program like "Get Data Back" to try and recover data off the bad/corrupted hard drive.
Jun 02, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
I have an old maxtor 2 drive that i'm trying to slave
Hi!
Just follow the jumper settings in the picture diagram below:
I hope it helps..
Thank you for reaching Fixya.
Apr 11, 2010 | Maxtor Hard Drive
Hi there, seem to have lost my external harddrive on my desk top, and it is making a beeping sound??
Hard drives don't beep. They make a lot of sounds, but no beeps. If the drive is actually making an unusual noise, it has probably gone bad. Clicking would be a bad disk. Any other noise would be a bad controller board. A good shop may be able to slave your drive to another computer to try and save your data. But don't count on it. By the time a drive makes a loud noise, it's usually gone and unrecoverable.
Before spending a lot of money to recover your data, try the external drive on another computer. Maybe the connection USB port has gone bad on the original computer.
Nov 12, 2009 | Maxtor Hard Drive
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Jumper settings for a Maxtor hard drive, Model 87000D8
Here's the chart that lists the jumper settings for all of the various models of Maxtor hard drives:
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
The first drive above is a DiamondMax 1750, and
the 2nd is a DiamondMax 4320
Feb 08, 2008 | Maxtor Hard Drive
This looks like documentation from the time but it is not from a manufacturer's site.
http://stason.org/TULARC/pc/hard-drives-hdd/maxtor/87000D8-DIAMOND-MAX-7000MB-3-5-SL-ATA3.html
near bottom of page.
Jan 01, 2008 | Maxtor Hard Drive
Jumper Settings
another place to look is on the circuit board where the jumpers are connected you'll see : MS, CS, CAB, a space and TXD.
Cheers
Oct 13, 2007 | Maxtor DiamondMax Plus 6800 (91366U4) 13.6...
Maxtor Hard Drive Logo
121 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
