Question about Juki MO-655 Mechanical Sewing Machine
JUKI MO-2416N - Thread break
I got the MO-2416N from my parents but I got the problem is the thread constantly breaking during my work. How do I go from here to diagnosis the problem?
3 Suggested Answers
SOURCE: juki mo 2316 nEEDLE THREAD KEEPS BREAKING
I took my machine in to a place that fixes machines.
Thanks anyway!
Posted on Sep 10, 2009
SOURCE: HOW DO I THREAD THE JUKI MO 2416N
HI THERE
CAN YOU PLEASE EMAIL ME ? I CAN SEND THREADUNG DIAGREM FOR THAT MODEL.
BEST REGARDS
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail.com
Posted on Mar 13, 2011
Threading diagram needed for the looping needles
There are quite a few pictures of threading diagrams on the internet. Just perform a search for the make + model + the word "threading."
Be sure to follow the threading order specified in your owner's manual. If the order is not followed accurately, the machine will most likely not work properly. Also, be sure to RAISE the presser foot BEFORE threading. While threading each thread, grasp the thread with one hand between the thread tree and the tension disk and grasp the thread below the tension disk with the other hand and gently tug the thread to make sure it has seated in the tension disk. With most sergers, the lower looper thread MUST drape over the top of the upper looper in its final threading process Before being pulled under the presser foot.
Juki MO 816 threading Google Search
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwiOt_7mqbHKAhVK52MKHc5XB5MQFggdMAA&url=http%3A%2F%2Fwww.raichert.com%2Fadobe%2FMO804-12-16%2520Inst.pdf&usg=AFQjCNH1vfonoEQ29McTsOItvQoW8ECZag&cad=rja
If any either looper thread breaks or comes unthreaded, it is the best advice to unthread all the looper threads and re-thread from the BEGINNING. Just bite the bullet and do it. It will save a lot of frustration.
Jan 17, 2016 | Juki Sewing Machines
Using Juki DDL555, Thread breaks when trying to hem jeans
Sometimes using a larger needle will help. That is if it's shredding the thread when it goes through the needle which causes it to break.
Mar 25, 2013 | Juki MO-644D Mechanical Sewing Machine
My Juki MO-655 serger will sew a few inches then the needle thread becomes disengaged in the stitch process. The machine will sew a few inches more then stops making stitches. I have cleaned the thre
Make sure you are threading the machine correctly. Make sure you are using serger thread that isn't old. Make sure you are undoing all the threads when it breaks and thread it from the beginning.
Make sure you have the right needles in their respective places. My Juki MO has two different size needles.
Sep 02, 2012 | Juki MO-655 Mechanical Sewing Machine
HI THERE
BEST REGARDS
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail.com
Jan 29, 2011 | Juki MO-655 Mechanical Sewing Machine
Breaking thread
there could be two things that I can think of right away, one the thread may be old, even if you brought it from the store, two, the needle is in the wrong way or it is the wrong needle .
Nov 11, 2010 | Juki MO-654DE Mechanical Sewing Machine
Juki mo 2316 nEEDLE THREAD KEEPS BREAKING
Thanks anyway!
Sep 09, 2009 | Sewing Machines
PFAFF hobbymatic 935 bottom-thread keeps breaking. It worked before but now it's not working
The Pfaff hobbymatic 935 was a mid to late 80's production machine (proudly made in West Germany, LOL) and was a transition between the older "oil me or I die" style of machine and the more modern "maintenance free" machines. Only one part of the machine needs to be oiled from time to time, the track around the bobbin. One drop of oil should keep her from snagging and breaking. If that doesn't do it for you try a newer bobbin thread as old thread can become weak sitting on the bobbin.
Hope this helps!
May 02, 2009 | Juki MO-644D Mechanical Sewing Machine
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
My thread is breaking when I'm sewing on my Juki DDL 555
MAKE SURE YOU HAVE THE RIGHT NEEDLE FOR THE THREAD YOU ARE USING, AND THAT THE SAME THREAD IS ALSO IN THE BOBBIN. CHECK UPPER TENSION, BY PULLING SLIGHTLY, IF IT'S TIGHT, LOOSEN THE UPPER TENSION.YOUR THREAD MAY BE THE WRONG SIZE OR TYPE FOR THE SPEED YOUR SEWING., and the needle your are using( sorry about the caps lock)
Oct 18, 2008 | Juki MO-644D Mechanical Sewing Machine
Juki MO-655 Mechanical Sewing Machine Logo
446 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
