SOURCE: my trunk will not open on my 2002 ford focus
It sounds like your latch has double locked. Here is the fun part, can you drop your rear seat and get into the trunk? If you can look for a tag that is possabily glowing pull it to release the emergency latch on the trunk. then with your finger lock the latch and check to see if it is leaving a large enough gap fot your pinky finger to fit in. if it is then you have reset it. if not then pull the emergency release a few more times
SOURCE: 1996 Ford Thunderbird LX (lights on outside of
The housing for the bulb is behind the cover. You will need to remove the screws (sometimes just push in clips that can be pulled out) and pull this cover off. At this point you should be able to see the wires going to the bulb/housing.
SOURCE: Keys locked in the trunk of a 1991 Ford Taurus ...
dont know if this helps but dose the back seats fold down
SOURCE: how can i reset my 1996 ford thunderbird airbag li...
I need to find a vacuume diabrame for an 1996 ford thunderbird lx
SOURCE: i have a 1994 ford
both buttons are right next to each other in the console glove box not the dash one
