Question about Brother MFC-5460CN All-In-One InkJet Printer
Have Brother MFC-5460CN print only in black
How can I save colored inks by occasionally printing only in black and switiching back to color when I need it? The user manual does not cover this question. I have pressed the black button thinking that would work but I still get color copies.
  • Anonymous Feb 02, 2009
    Brother MFC-5460CN online help states can't be done.
    I cartridge,I used a piece of black tape to cover the eye that the printer reads and changed to print grayscale and mine works.
    Don't know if same will work for you, though.
    Sergeant:
  • 236 Answers
You should be able to do this in the printer properties when you go to print.
Posted on Dec 08, 2008
I have a all in one color LC61 printer, do all colors have to be filled to print blk only?
Greyscale is color not black only.
You can print in black and it will look grayscale only darker, printers are a pain to work with after a year has gone by, I can expect almost a half hour to print something with my $400 epson because one of the colors is out even though I never printed in the last year a colored page. I take the color cartirges out and they are empty, but I only print a page 2-3 times a year. I use the scanner all the time. Brother and epson have their print heads in the printer not the cartridge so make sure your inks are always have something in it or it will be miricle for the printer to last more than a year. Check colors every other week. One Epson printer only lasted 3 months because I never used it(print head dried up). Never use the set up with tubes running outside printer to small tanks of ink if you only use it occationally.
May 11, 2014 | Unknown 10pk 4B,2C,2M,2Y Compatible LC61...
IMPRESSION IMPOSSIBLE .4F
change your print head, and the printer will work perfectly.
when changing print head don't use chineese ink, use brother original ink, to save your head,
Hot Sell Printhead For Brother Mfc J825 Print Head Buy New And Original... Printhead Mfc j220 Mfc j615w Mfc j410 Dcp j125 Printer Head Buy Print Head...
Oct 05, 2012 | Brother MFC-J220 All-in-One Color Inkjet...
Does printing black text only on a Brother Inkjet All-in-One (MFC-J625DW) use the color cartridges?
Your right. Simple answer. Take the coloured cartraiges out (you may need to set your printer to mono crome though. not sure.? Save a bit more money and recycle your cartrages you get paid for them. then you can buy refill cartrages and save even more. Some say do not use them they cause problems, but i have from day one and still have no problems 29 years later!!! and i am a high user on a A1 PRINTER!!! (draughtsman if your wondering)
Jan 25, 2012 | Office Equipment & Supplies
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
Toubleshooting and routine maintainance is what comes oout on myscreen
Found this on the web. Click on link below to print the entire manual out to keep. Below are steps to do cleaning. If you find this helpful pls rate me. Thanks and Good Luck.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
How to improve print quality Cleaning the print head
To ensure good print quality, the MFC will regularly clean the print head. You can start the cleaning process manually if needed. Clean the print head and ink cartridges if you get a horizontal line in the text or graphics on your printed pages. You can clean Black only or three colors at a time (Cyan/Yellow/Magenta), or all four colors at once.
Cleaning the print head consumes ink. Cleaning too often uses ink unnecessarily.
Caution
Do NOT touch the print head. Touching the print head may cause permanent damage and may void the print head’s warranty.
1 Press Ink.
2 Press or to select Cleaning.
Press Menu/Set.
3 Press or to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished, the MFC will go back to standby mode automatically. If you clean the print head at least five times and the print has not improved, call Brother Customer Service (see Brother numbers on page i).
Checking the print quality
If faded or streaked colors and text appears on your output, some of the nozzles may be clogged. You can check this by printing the Print Quality Check Sheet and looking at the nozzle check pattern.
1 Press Ink.
2 Press or to select Test Print.
Press Menu/Set.
3 Press or to select Print Quality.
Press Menu/Set.
4 Press Color Start.
The MFC begins printing the Print Quality Check Sheet.
5 Check the sheet to see if the quality is OK by following these steps:
Color block quality check
The LCD shows:
6 Check the quality of the four color blocks on the sheet.
7 If all lines are clear and visible, press 1 (Yes), and go to Step 10.
OR
If you can see missing short lines as shown below, press 2 (No).
The LCD will ask you if the print quality is OK for black and three colors.
OK Poor
Is Quality OK?
1.Yes 2.No
Black OK?
1.Yes 2.N
8 Press 2 (No) for Black or three colors
with a problem.
The LCD shows:
Press 1 (Yes). The MFC will start cleaning the print head.
9 After cleaning is finished, press Color Start. The MFC will start
printing the Print Quality Check Sheet again and then return to
step 5.
10 Press Stop/Exit.
Jan 14, 2010 | Brother MFC 210C All-In-One InkJet Printer
Print is faded. I just replaced the ink jets.
You said you just replaced the ink jets. Did you clean the print heads? Here is Link on Web. If you find this helpful pls rate me. Thanks
once.
unnecessarily.
Caution
1 Press Ink.
Press Menu/Set.
Press Menu/Set.
numbers on page i).
Jan 11, 2010 | Brother MFC 210C All-In-One InkJet Printer
Print head for brother mfc420cn
once.
unnecessarily.
Caution
1 Press Ink.
2 Press ▲ or ▼ to select Cleaning.
Press Menu/Set.
3 Press ▲ or ▼ to select Black, Color or All.
Press Menu/Set.
Hope that helps,
Take Care,
Michael
Nov 13, 2008 | Brother MFC 420CN All-In-One InkJet...
No color
Make it sure that ink cartridge are genuine not generic , sometime the generic ink the printer connot identify because the small chip at the back of cartridge are defferent from genuine ink.Sometime the generic can print but not true color, genuine has a perfect color and you will satified save time , money ,and effort.
Dec 20, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-620CN Printer
my brother mfc-620cn printer is printing backwards if you had a see threw paper itnwould look right
Jan 26, 2007 | Brother MFC-620CN All-In-One InkJet...
Brother MFC-5460CN All-In-One InkJet Printer Logo
97 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
