Question about GE 25GT511 25" TV
GE Model #25GT511 Power on, no picture or sound
You can hear the power come on, but there's no picture or sound. I've tried hooking TV up to the VCR and play a tape, same result. Chassis #CTC185AA. Thanks.
    Sergeant:
  • 337 Answers
The question I have is if the tv stays on but with no pix or sound,we have a way to check,if you place your forearm in the face of the picture tube and the hair in your arm stands up it means you have the high voltage needed to light up the tube but something else is missing like the screen voltage or it has a loose conection in the crt board,if the hair in your arm does not react to static then we are missing the high voltage and the problem might be more involved and related to the horizontal circuit not creating the high voltage needed.If you are familiar with tv service you have a few places to check but if you are not to familiar play it safe and call for assistance from a professional servicer.Let Us know how it goes please.
Posted on Oct 26, 2006
  • Omar Urrutia
    Omar Urrutia Oct 26, 2006
    Your rating response is also important.
Owners guide GE VCR model VG2001
Note: most remotes allow you to find the code by manually turning the TV (or other device) on first, then press the appropriate button (cable, DVD, surround, etc) then setting the the remote in the "program" mode, then keep pushing the "off/power" button until the TV (or other device) turns off, at that point the code is set.
Oct 16, 2014 | General Electric Vcr Remote Control...
Lost Manual. "Clock set, year, month, etc." on screen. Working with "Menu" button doesn't fix it. How do I get it off?
There is usually a cancel button.
If that does not work, try unplugging the TV power cable for two minutes.
If still no luck , then give me the complete model number, or enter the model number here to access manual.
Regards.
Nov 18, 2009 | GE 25GT511 25" TV
Old GE TV picture turns off, sound stays on, after a few minutes
it is problem tv power curcit stavilizing section or power cercuit dry soldering
Sep 06, 2009 | HP Md5880n 58 in. HDTV
Connecting a toshiba sd-v392 to an old analog tv
Make sure your menu settings are correct audio outputs may have a setting for digital or analog sound output check that these are set up to analog or stereo output .Also try hooking the sound up direct to a stereo system or amp to be sure you have output! Also you may not be able to get your sound thru the convertor box!! Because the convertor is a reciever of digital signals not a line amp. for audio !! Hope this helps11 AAAAAAAAAAAAAE!!!! Swampratt200 ! Out!!
Jul 21, 2009 | Toshiba SD-V392 DVD Player/VCR
SharpVision Model 64LHP4000: Hear a clicking sound coming from back of tv, solid red light, on front, comes on but no picture or sound.
Is your antenna connected or you cable satellite hook up to the TV? you need a signal of some sort to activate the TV circuits. Try a vcr or dvd player hooked to the set put in a tape or a dvd!!
Jun 30, 2009 | Sharp Televison & Video
Can't get my VCR to work
FIRST!!! Make sure you have the coax or AV cables plugged into jacks marked out on the machine.....then....
*If you have it hooked up with a Coax cable, you should immediately have picture and sound when you turn it on. Make sure you have a dvd/vhs running and switch between channel 3 and 4. if this doesn't work, make sure that you have the cable connected to the one marked 'in' or 'cable in' or 'ant in'. then retry the previous steps.
*If you have it hooked up through A/V cables (Red/Yellow/White), make sure you have them all connected to the same set of jacks. They should be labeled Aux 1 or something similar and are generally surrounded by a box molded into the TV's plastic casing. You will then have to use the TV remote to switch TV/Video settings until you get to the one that matches the Aux jacks you have it plugged into. Again...make sure a dvd or vhs is running and keep flipping until you find a picture.
Hope this helps!!!
Dec 29, 2008 | GE 25GT240 25" TV
Sleep timer
It does, through the menu function
Jun 11, 2008 | GE 25GT511 25" TV
Not a good signal
You may have a connection problem, particularly check the cable which goes from VCR output to TV input. The RF signal is carried on the center conductor of the coax cable. If you look at the end of the coax, you will see this center wire. If this wire is substantially recessed (too short) or bent over, then it might not make contact with the connection of the VCR tuner out or TV in. Try a different interconnection cable. If problems still remain with this substitute cable, when you have things all hooked up, try moving the cabling from side to side, and see if the picture quality changes substantially. Another possibility is the tuner in the VCR is defective. If so, repair is not economical- replace the VCR.
Aug 29, 2007 | GE VG2050 VHS VCR
No picture, no aundio
most tv/vcr combo has only one power supply source which is located in the vcr unit. u have a power supply circuit problem. try to check the rectifier, filter capacitor and the regulator ic/transistor. good luck!
Feb 02, 2007 | Toshiba MV13L2 13 in. TV/VCR Combo
Televison & Video Logo
99 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
