Back to:
Tags:
Samsung SyncMaster 940MW  19
Intermittent Power Supply
posted by threeputt on Oct 25, 2006
Have recently purchased and have only used as tv. Sometimes even though plugged into an active outlet, can not get any green power light at the screen. A day or two later it will work ok. Sometimes after minimal use it will shut down or it will go to a mode where none of the remote will work. Unit worked good for the first couple of weeks without any of these problems. Have not used it with a pc yet and have not configured it with any supplied software as yet.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Feb 25, 2007
Thanks for Trying (70)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
There is a high resistance short between the pins on the board for the channel/volume/power etc. buttons. This can be verified by ohming between the pins on the board. Clean around the pins to remove the short.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Intermittent Power Supply:
I don't want to Accept this solution
Solution #2
posted on Apr 25, 2007
Not Rated (0)
Tec7
Rating: 0%, 0 votes
As with most Korean & Chinese manufactured products, the quality of construction in the factory can be less than desirable. We often find problems of this nature to be due to poor connections:sometimes it's as simple as the various cabling & harnesses between individual circuit boards & modules (those going to the light engine in Samsung DLP & LCD sets are notorious), but more commonly it's about the lead-free solder that the E.P.A. has mandated must be used in new electronics products for the U.S. market---lead-free solder requires higher temperatures to flow than older lead-based alloys, while the wave-soldering robotics used by these manufacturers is apparently still capable only of what they were designed to do, i.e., working with lead-based solder. Perhaps 25-30% of the problems we repair are of this nature...
Thank You!
Solution #3
Not Rated (0)
okan
Rating: 0%, 0 votes
I have same problem too. My monitor shut itself every 20 to 30 minutes.Only way i bring'em back on is unplug the monitor.But this is not the solution.
Thank You!
Can you Help with these Monitors problems?
Samsung SyncMaster 940MW (Silver) 19" LCD...
we have tryed to plug our ps3 into the dvi conection via...
screen is split horizontally in thirds.  top third...
The screen of my Advent 7201 laptop broke a few weeks ago,...
The remote has been erratic for several weeks, it seemed...
i turned on closed captioned on my syncmaster 940mw a few...
Loading problems.
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
