Question about Vacuums
Porter Cable 7814 vacuum
I am having trouble with my vacuum. it keeps going on and off. The first five minutes works good and then it start with the on and off. It will do this even if I am not using the tool triggered switch. Can you help me please.
    Scholar:
  • 116 Answers
Possibly a faulty power cord, replace the power lead to the machine or check for damage to the cable.
Check that machine is not blocked, motor may be overheating due to blockage, if you have good suction this indicates machine is not blocked.
Posted on Nov 09, 2008
I have the porter cable 10 gallon tool trigger drywall vac why is it that the bags keep braking. Have had it for years and it's only been about the last two years they rip open way before they are half...
Need some more information, are you vacuuming dry wall dust or wet dust or saw dust ? The reason I ask is sometime their are "upgrades" available for the newer models of vacs you may not be aware of, when I worked at the Big Box H D tool rental center the vac we rented out used a water filtration set up instead of bags U might wont to check newer model for any changes, like you ,I had Craftsman for over 15 yrs. and when it died the replacement vac had a new mod for the filter that I always thought was needed. Good luck , Bret
Sep 28, 2014 | Porter Cable 7812 Wet/Dry Vacuum
VACUUM FAILED TO AUTOMATICALLY START AFTER PUTTING ON A NOTHER POWER TOOL
did it start and run for a second before you tryed pluging the power tool in
Feb 18, 2013 | Porter Cable 7812 Wet/Dry Vacuum
Why does the motor start, then shut off?
Check for a stuck or binding float switch
Jan 31, 2013 | Porter Cable 7812 Wet/Dry Vacuum
My Broan-NuTone central vac shuts off after I am vacuuming for a couple of minutes. I turn it off for about 10 minutes and start vacuuming again and it keeps shutting off. What is wrong with it? I...
Some of these units have had trouble with the motors and this is what causes them to shut off. NuTone has been pretty good about replacing them under warranty. 1-888-336-6151.
Aug 17, 2011 | Broan-NuTone VX475 Bagged Central System...
Where can I buy replacement bags ?
Porter Cable is a professional tool store product. Look at a Porter Cable dealer,or online nowhere else
Oct 27, 2009 | Porter Cable 7812 Wet/Dry Vacuum
Cutting out after five minutes use
sounds like not good air flow check for blockage new filter
Aug 11, 2009 | Vacuums
Atttix 8 Gallon AS/E
make sure your knob is set to the right hose diameter, the inner cage is properly seated inside the filter and your float is not being obstructed by debris.
Oct 16, 2008 | Alto 302000414 Attix 8 AS/E Canister...
Nutone central vac vx550
It's a known problem. I bought my vx550 last year in July and it stopped working this year in May. On for 5 minutes, shut down, can't run for a few hours, runs for another five minutes, etc. I called the Nutone customer service department and they exchanged the unit for a new one, cross shipped, via UPS. Mine was still under warranty though. It has to do with some defective thermostat or controller in the electronics of the vacuum.
Good luck
Sep 11, 2008 | Broan-NuTone VX475 Bagged Central System...
Porter Cable Roofing nailer rn175a
Replace the O Rings and the trigger valve assembly. 9/10 sticking rods on the Porter Cable guns is caused by a faulty TVA.
Nov 08, 2007 | Vacuums
Vacuums Logo
56 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
