Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Bios password Primary master hdd pasword was set on my computer , and I am unable to use my computer . It was set during when set in for repairs and now acer wants me to pay to get it rid of the problem. Any suggestions?
  • Lalit Varadpande
    Lalit Varadpande May 11, 2010
    is it a laptop or desktop?
    Scholar:
  • 126 Answers
If you mean you cannot access the bios due to a password protection, open the case and remove the battery for 1 minute and then replace it, this should clear the bios password so you can access the bios setup.
Posted on Nov 09, 2008
Emachine eme 442 hard drive password problem how to reset it any master possword have where is jumber setting
When you boot up to the log in screen type in administrator as user if you cant log in
During the boot up process you will see on the screen for a short amount of time a certain key to enter set up press and hold that key to enter set up BIOS scroll to set user password or supervisor password you can change or remove the password from there if you are still unable to change your password you might download
http://download.cnet.com/%7Bvalue=http://www.download.com/ubcd4win/3000-2086_4-10550208.html
UBCD4Win is a bootable "live" CD which contains software that allows you to change paswords repair/restore/diagnostic almost any computer problem also has a bios reset tool which remove your password and BIOS password although you will have to use a computer with an internet connection you will have to burn it to a disk as an iso then change your firtst boot device to cd During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed the password you must go back and change the first boot device to your hard drive)
Hope this helps
May 22, 2011 | E-Machines (308714) Motherboard
After boot, appears ENTER PRIMARY MASTER HDD USER Password i need the password @ solution to boot up my lappy... thanks
How Do I Change the Primary Master HDD User Password?
Prior to loading an operating system, your computer will first execute the BIOS program. The BIOS has an extra password feature, called the hard disk drive (HDD) user password, that can't be bypassed and provides a layer of defense to keep your data secure. To change an existing HDD user password you will have to load the BIOS menu, which is only accessible during the computer's operating system reboot procedure.
Instructions
1. Close any windows that are currently open on your computer. Eject any discs inserted into the optical drive and disconnect any peripheral USB devices.
2. Open the "Start" menu and select "Shut Down." Turn on your computer once the operating system finishes shutting down.
3. Press the key your computer uses to load the BIOS menu. For example, with Dell computers tap "F2" when the "Press F2 for Setup" option appears. Press the "Access IBM" key on IBM laptops or "F10" on HP desktops.
4. Navigate to the BIOS tab that contains the HDD password option, which will usually be the "Security" tab. Some computer manufactures instead include the password option in the "Advanced" tab.
5. Scroll down to the option labeled either "User Password" or "BIOS lock" and hit "Enter." Type the current master HDD user password when the prompt appears and press "Enter."
6. Input a new HDD user password and hit "Enter" again. Navigate to the BIOS tab labeled "Exit" or something similar.
7. Move over to the "Save and Exit" entry and press "Enter." Select "Yes" and tap "Enter."
Nov 15, 2010 | Acer Aspire 5610 Notebook
Hdd primary pasword is lost cannot open hard disk drive showing error codes 06231 and so on cannot boot the computer cause the disk drive is asking for primary hdd pasword and is no taking the password...
Most modern laptop HDD or BIOS passwords are not resettable and don't come with default passwords to unlock them if the password is forgotten.
You will need to contact Acer and find out what kind of warranty coverage your machine has. It's likely that you will have to pay for the services they provide or pay for a new hard drive yourself and re-install Windows.
Aug 10, 2009 | Acer Aspire 5535-5050 Notebook
Need to bypass primary master HDD user password
send me ur email and I'll give you link for software to remove all passwords in bios or windows
Jan 26, 2009 | Dell Inspiron 2650 Notebook
Sata HDD set in primary master in Bios
Try considering these:
1. DOS disk doesn't recognize SATA, that's the truth
2. You're going to have a problem if you install OS in your computer (solution: do not select SATA in HDD type but rather IDE)
3. For your SATA HDD to become primary (boot first) try to select your SATA HDD as devic first to boot..
Jan 04, 2009 | Maxtor Hard Drive
Clear BIOS settings
i have acer aspire5570z laptop. i have forgoten my primary master hdd user pasword. how can i remove it ? plese help me
Aug 21, 2008 | Acer Aspire 5610 Notebook
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
87 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
