Question about Frymaster Dean H22 Deep Fryer
Frymaster fryer keeps calling for help on electronic keyboard.
We have a Frymaster gas fryer and it intermittenly calls for help. We have checked the fan to make sure it is clean and it seems to be getting good air flow. Any other Ideas?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 107 Answers
There should be some kind of spark sensor usually where the gas line plugs into the pot. There is one wire hooked to it take the sensor out and clean it good. Soot could be building up on it causing it to nolonger sense a flame.
Posted on Apr 19, 2012
    Novelist:
  • 75 Answers
I Found a manual on line for your electronic controls. The HELP display is telling you that you have a heating problem. The book says to shut the fryer off and call the frymaster Technical Service: 800-551-8633. Ask for a service tech. They could probably talk you through some things you could check. If you have and know how to use a voltage/ohm meter and a few tools they may even troubleshoot it over the phone with you. You might want to check all the safety switches first like oil drain valve switch. Listen to it when the HELP display comes on and see if the flame is still burning or trying to light, is the fan running? These things will help you explain what its doing. Hope this helps. kstfas P.S. If you are not familiar with electric and how easy it will make your hair curl......... HA. Do Not Attempt any tests that involve live circuits. Good Luck http://www.frymaster.com/general.asp?article=servicehome.xml http://www.frymaster.com/iframe.asp?oc=fry®ion=default&article=onlineliterature.xml
Posted on Oct 25, 2006
Operational Manual
There's a list of manuals for Frymaster units here, yours isn't listed but maybe it's called by another name: http://www.frymaster.com/?xhtml=xhtml/fry/us/en/minisite/service/manuals.html&xsl=minisite.xsl
Feb 20, 2011 | Frymaster Dean H14 Deep Fryer
Getting 400 ppm of co at vent
Too much CO is a result of a rich burn mixture...
Check to make sure that all the burner shutters are wide open...
If they are all open then the gas pressure needs to be turned down at the gas valve...
The screw to set the pressure is under a cap screw on the gas valve...
open the top and then turn the inside screw up or CCW to turn the flame down...
heatman101
Jan 15, 2011 | Frymaster Dean Frymaster/Dean FPEL3 Deep...
Hi, Frymaster electric fryer. When unit is turned on the right display shows "prob" and it beeps
There is a problem in the system. The problem is usually a sensor that is not reading correctly or not working right.
To troubleshoot this type of problem it is best to call the factory tech. support people and have them walk you through the troubleshooting. then they can also guide you to getting the proper replacement parts. For a problem that is showing up like that you will need OEM parts anyway.
heatman101
Dec 09, 2010 | Frymaster Dean FM345EETC Deep Fryer
I bought old frymaster fryer and want to use it at
Yes, just make sure that you have the standard size of the orifice and the right gas valve spring.
Regards.
Mar 27, 2010 | Kitchen Appliances - Others
I need wireing diag for filter systen for frymaster mdl 350oced sn 9608ieo147. gas fryer. thanks i just need wireing diag
Hello. I think this is what your looking for:
http://www.frymaster.com/?xhtml=xhtml/fry/us/en/general/manuals.html
Go here, scroll down the page until you get to H50 units, and click on the link that has the SP manual, 819-0001 next to it, page 32 describes the different filters, and 61 has the wiring diagrams.
Hope that helped, and thank you.
If you need more help, "ask me"
Apr 10, 2009 | Frymaster Dean Kitchen Appliances - Others
Heating problem with frymaster h14-2
I called IG Service in Denmark, who have their own technical experts, And they will now solve it.
I found them via the frymaster homepaige.
www.ig-gruppen.dk
Jan 15, 2009 | Frymaster Dean 2424G Deep Fryer
Frymaster fryer mj45eusd
If this is an electric fryer you may have a shorted element that will continue to heat when ever the fryer is turned on,even when it is not calling for heat. If it has 3 phase power, the elements could be wired wrong
Sep 08, 2008 | Frymaster Dean Kitchen Appliances - Others
Frymaster blowing back fire
google sams manuals.is your fryer propane or natrual gas if so the baffles and orfices in the fryer are clogged.propane burnes very dirty.
Aug 12, 2007 | Frymaster Dean 2424G Deep Fryer
Frymaster Dean H22 Deep Fryer Logo
890 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Thomas Perkins
Thomas Perkins
Paul Carew
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
