Question about Garden
Troy bilt tb25cs pull cord not rewinding
I have the shaft removed to the silver bell where the shaft slips in. how do i get to the cord from there?
5 Suggested Answers
SOURCE: Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Posted on Mar 21, 2009
  • 57 Answers
SOURCE: I need to know the spark plug gap.
.030
Posted on May 19, 2009
  • 32 Answers
SOURCE: pull cord won't rewind
the shaft isnt attached right.
Posted on Jun 12, 2009
  • 279 Answers
SOURCE: Will cleaning my Troy-Bilt TB25CS carburetor heal it?
Since the air from the air filter does not go through the carb, the carb cleaner will not either. If you remove the carb and spry all of it that you can get to, you may get the plug. If you were to open the carb and go through it and clean it you would need to get new gaskets and maybe that will do the job. You may be able to adjust the carb. There is a "hi" and "low" setting. Try adjusting the "hi"...Lee
Posted on Aug 24, 2009
Testimonial: "Thank you for getting me started! Hope I can get a little more info on the process! "
  • 5 Answers
SOURCE: finding a shredder screen for troy-bilt
Just found some parts for my Troybilt Gardenway chipper-vac Model 47279 on this website http://www.partsandservice.com/bin/ipl.cgi
I would think they might have something for your machine.
Posted on Oct 12, 2009
Troy bilt pull cord wont retract
Recoil spring is broken or slipped out of retention slot. Coil needs to be retentioned or replaced. Unless you have done this before I recommend taking to pro. This is easy job if you have the jig but almost impossible if you don't.
Jun 29, 2014 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How do i remove the bump button
Hello.
It should pull straight off. Here's a link to a tip page that explains how to rewind one:
http://www.fixya.com/support/r2827867-winding_line_trimmers
Best regards, --W/D--
May 04, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Pull cord replacement
You don't, you must remove the entire housing to replace rewind parts.
May 31, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Cutting attachment will not advance
Remove the spool, remove the cord and discard. Rewind with fresh cord. Sometimes the cord is overheated during operation and melts together - does not advance. A fresh setup usually fixes the problem.
Mar 30, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Pull Cord Will Only Pull Out 3-4 Inches Then Sticks
Take it apart as you did before. Look for whatever it is binding. Did you rewind the rope so there is a good amount of tension? If you didn't, then do that . Good luck, Lee
Sep 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Aug 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
I have an older Troy-Bilt Pony Garden Tiller witha
From what I read you need a new rewind clutch and the spring and cord go into the housing. Briggs is easy to fix. contact me at kerryjonjon@yahoo.com and I can send you what you need or you can send it to me and I will repair it very cheap!! Parts are available at almost any small engine parts place.
Jul 17, 2009 | Troy-Bilt Pony Garden Tiller
I waz starting the awn mower and had resistince from the pull cored so i pulled and now the pull cored is dangolling and want trigger a start
Soundas like the rewind spring is broken. Remove the top housing and see if you can reset the spring by removing the cord, hook up the broken end, rewind the spring with a screw driver...lock it in the tension position and then reinstall the cord.
Jun 15, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Garden Logo
541 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
