Question about SanDisk Sansa e130 MP3 Player
Expansion card I deleted the songs from the expansion card I used with this device. It reads the device, reads that it is writing to it, but is not able to recognize any of the songs on the expansion card, just the internal memory. The card can be read in a separate card reader device, which shows all the songs as being there, so the card is functioning fine. These are the same songs which played off the same expansion card before, so format compatability in not the issue. The device just appears unable to refresh the song list and add the new ones. Please advise.
    Problem Solver:
  • 7 Answers
The issue with the card is not song format as you said it's the card format. When you put you're it into the CPU I?m assuming that you clicked yes on the warning/and or problem window and it formatted it to the CPU. So what you need to do is find what format the hardrive /and or internal memory is and format the card to that.
Posted on Oct 25, 2006
Won t recognize sd card
It seems that the card reader if the computer is not detecting the card. Make sure that the memory card you use is supported.
The multi-in-one card reader on the Aspire One can read and write to Secure Digital card (SD), Secure Digital High Capacity card (SDHC), MultiMediaCard (MMC), Memory Stick (MS), Memory Stick PRO (MS PRO), and xD-Picture Card (xD). Specific models of the Aspire One are also equipped with an SD Expansion slot that can read and write to Secure Digital (SD) and Secure Digital High Capacity card (SDHC) cards.
The multi-in-one card reader on the Aspire One can read and write to miniSD, microSD, Memory Stick Duo,and Memory Stick PRO Duo cards but require the use an adapter. Acer does not provide or support any memory card adapters.
You can try removing the card reader using the device manager and the reinstall it and check the operation. You may also try using the card is different computer and check. Also try using another card in the computer with the issue and check. If the issue is not resolved please revert back with the model number.
Click on the link for the information to Reinstall a Device
http://technet.microsoft.com/en-us/library/cc725782.aspx
Nov 14, 2013 | Acer Aspire Computers & Internet
Tip
Memory Card Locked / write protected error.
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Memory card write protected, memory card locked, memory card will not read, can't use memory card.
on Jan 10, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
Windows mEDIA PLAYER SAYs my sansae260 is full, but device won't sync. It says no song. I tried to reset, but still says no song
change the usb modes also....MSC will allow you to see the expansion card ( 2Gig E200 series 4gig Fuze) mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion.....
Delete songs and Format (Helps with trying to delete BAD TRACKS and folders that will not delete full memory(Some ripped CD folders).. Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders themselves then format a couple of times hope this works
Jun 21, 2010 | SanDisk Sansa e260 MP3 Player
I cant delete any songs
The e200 series players have 2 versions, plus a Rhapsody version.
How to check your version:
On the player
1. Go to the Main Menu
2. Select Settings
3. Select Info
4. Check the firmware version, if it says
v1 it is a version 1
( or Rhapsody
Rhapsody also supports Rhapsody service and channels
USB mode is Rhapsody/PlaysForSure instead of MSC/MTP for
the normal v1
Rhapsody fonts are smooth, antialiased )
v3 it is a version 2
Having a version 2 player, songs can be deleted on the player itself:
1. In playback mode, press submenu.
2. Select the Delete Song item.
For all versions you can delete songs:
1. Making a connection to a computer first.
2. Use the Windows explorer on the computer:
Select "My Computer" on the desktop and go to the internal memory or expansion card of the e250:
Go into the MUSIC folder. Select your songs inside the MUSIC folder and select delete.
Need more information ? Just post a comment.
Dec 31, 2009 | SanDisk Sansa e250 MP3 Player
I can only load 75 songs.I have 2.0gb and a2.0gb card.I cannot format.I take the card out and I have one song in the player.With the sd card I get about 75 songs.Windows Media shows many songs synched but...
Delete each song manually and then folders from both the card and player there may be a boot file something Open music folder and click on tools folder options click view click on the circle show hidden and remove checks from hide and hide remember to undo these changes later go check the card and player manually delete anything....Then try and format a coupe of times....Drag and drop all of the music in to the music folder on the sansa and anywhere on the expansion card easier knowing what you are putting on the player.........
Aug 07, 2009 | SanDisk Sansa e260 MP3 Player
Can"t delete 115 songs from my sons Disney Mixmax PLEASE HELP????
Is there a card in the SD card slot? If so, check that the songs are not on the card instead of the unit. Just remove it and see if they are still there. If so, check when in media player if there is more than one device listed. With mine, it will list the device twice, usually one is reading the internal memory and the other one is reading the SD card. Make sure to check both.
Apr 08, 2009 | Disney Mix Max Digital Media Player
Messed up songs
Whatever you do, don't delete the whole folder - it will permanently mess up your GoGear. Here's what I would do: run a Repair in the Philips Device Manager OR update the firmware on the player if it won't let you do the repair - the reason that I am suggesting this is that it will delete all of the music files off your GoGear so that you can start over from scratch, as a side effect. Once everything is deleted, change the Rip format in Windows Media Player to Mp3 - it will not give you special options like read-only, etc. Then, re-rip the CD's and load the mp3 files onto the GoGear.
-Tha Mp3 Doctor
Mar 18, 2009 | Philips SA5125/37 MP3 Player
Can't delete Songs.
if you have a cd rw (read/write) device and a cd rw disc then you can delete songs. same is true for dvd...must have dvd rw capabilities. if you have the rw capability, and still cannot delete then there is a problem with the hardware or software of the device or windows.
Sep 06, 2007 | Computers & Internet
Can't delete files
Try formating the Sansa by right clicking it on my computer and then choosing format.
Aug 18, 2007 | SanDisk Sansa m230 MP3 Player
I cant delete songs off of my mp3 player
did you try going into (if you have a windows pc) My Computer, and navigating to where your player is (your player should be hooked up to your pc via a usb cord - the one that came with your player). your player could be in a removable disk - mine is (J:), or it could be under Other (all of this is still in My Computer). Click on different removable disks if you have to, until you find the one that has your player. Once you have found your player, double click to go inside it. Inside of your player should be a list of folders. One of them should be named Music. It could also have a Playlists folder, an Audible folder, or a Pictures folder, etc. Click on the Music folder. You should see a folder of all of your songs, OR you will see your song files. Select the ones you want to delete, right click and select Delete, or drag the files to your recycle bin. Hope this helps!
Apr 08, 2007 | Coby MPC-848 MP3 Player
SanDisk Sansa e130 MP3 Player Logo
49 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
