Related Tags:
This problem should be removed because:
Problem with Samsung HL-T5687S Television
Modified Picture Settings Reset Each Time TV Is Turned Off/On
Hello;
I have 2 Samsung HL-T5687S televisions, having owned them for the past 8 months or so, and both have operated without issue, with the exception of the remote control for one of them, which doesn't seem to function properly e.g. when trying to turn the power on, the light under the TV button flashes continuously, but no action happens. As a result, I've been operating this TV more-or-less manually since I've purchased it.
I have set the picture settings for both TVs identically (Movie; Contrast=100; Brightness=43; Sharpness=0; Color=42; Tint=G53 R47; Color Tone=Warm 1) and I set the light effect to be always off.
Last evening, the remote wasn't working as usual, and I wanted to set the sleep timer, so, for reasons that escape me, I tried using the remote from the other TV, which worked. However, within an hour, and while watching a movie on a DVD player, the picture settings reset to factory (I believe), and the light under the power button came on and stayed on.
Now, whenever I turn the TV off and then on again, the picture settings revert to what | believe are the factory settings (Dynamic; Contrast=100; Brightness=45; Sharpness=75; Color=65; Tint=G50 R50; Color Tone=Cool 1) and the light effect to be always on.
Any idea on how I can remedy this i.e. not have the picture settings I make revert to factory every time the TV is turned off then on?
Would it be worthwhile to go back to basics and start again e.g. from Plug and Play initial screen to set up the TV, as when I first received it? If so, do you know how I can get to that screen? I've looked - can't seem to find it.
Finally, I have unplugged the TV a and let it sit for 10 minutes before turning it back on. The problem persists.
Any help would be most appreciated.
Thank you.
Solutions (1)
Best Solution
Your TV may have been put into shop
mode or demo mode.
How to get out of "Shop
Mode"
1. Press [Source] to get to the Air or
Cable input on the TV or TV remote
2. Press [Volume +] once on the TV itself
(not the remote)
Next step must be completed while
the volume bar is still on screen
3. Press and hold [Menu] on the TV itself
(not the remote) for about 7 seconds
If the screen
flashes "Dynamic Mode", the process worked
4. Finally check whether the Picture Mode
is "Shop Mode" or not after passing "INFO" on Remote Control. If picture mode is still in “Shop Mode” try the
alternative way below
Alternative Method
Press [Source] on TV remote to get
to the AIR or CABLE input
Press [Menu]
Press [Down Arrow] to highlight
SETUP and press [Enter]
Press [Enter] again on PLUG AND
PLAY
Wait 10 seconds
Press [Enter] to select ENGLISH (or
choose an alternative language
Press [Right Arrow] to highlight
HOME and press [Enter]
Press [Menu] repeatedly until you
see the message ENJOY YOUR WATCHING
Confirm you are out of shop mode by
pressing [Info] on the TV remote
samsung tv settings
What are the best settings so that I can get the best picture from the samsung LCD tv model LE40M86BD?
LN-T4661F ghosting/blurry/double vision on...
LN-T4661F ghosting/blurry/double vision on warm-up. Once the TV warms up from bteween 15mins and several hours it has a perfect picture. ...
LOOKING FOR PICTURE SETTING SAMSUNG
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
The TV picture shows a
The TV picture shows a double image like "ghosting"?
Add Your Solution
how to clean inside Samsung 56'' LED DLP...
I Know this Tv doesnt have Lamp its LED DLP and Dust can cause issues. I am trying to find out how to PROPERLY DUST OUT...
I have 2 Samsung HL-T5687S televisions, having owned them for the past 8 months or so, and both have operated without...
Watching tv screen went black
Watching tv screen went black turned off back on and now the color is only blue and green. No Red. What's the...
No Red in my Samsung DLP LED TV Model HL-T5687SA
No Red in my Samsung DLP LED TV Model HL-T5687SA what is the lamp number
Fix-O-Meter
714
714 people viewed this problem
- 8 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Samsung Flat Panel Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
