Question about Mitsubishi VS-60607 TV
Blurry tv when first turned on
When first turning on set the picture is blurred with very poor resolution and color. No other distortions or lines. But after a few hours of being left on it clears up. Is it the bulb and where would I get one. It seems that Mitsubishi doesn't list the bulb as a part.
  • Compositor Mar 03, 2008
    TCL 76cm CRT widescreen TV. Model: TF-W76B03.
    Blurry when first turned on, gets to a very reasonable stage of sharpness after about five minutes and improves from there but never full clarity. Lighter colours more blurry than darker colours.
    Sergeant:
  • 337 Answers
The keyword for me here is blurred "at first,a bad bulb will only give you a dark picture being defective or with too many hours,The bulb is not consider a part ,is an accessory to the manufacture and is part of the market strategy.The problem in your set might be an slow charging capacitor in the power supply or in the ballast board,the ballast board is in charge of the supply volts to the lamp,if you are familiar with tv service you can check these circuits but if you are not too familair be safe and call for assistance from a servicer.Let Us know if you need more information.
Posted on Oct 27, 2006
  • Omar Urrutia
    Omar Urrutia Oct 27, 2006
    Your rating response is also important.
SOURCE:
We have a LG42lx6500. when you turn it on after being off for a few hours the picture colour is distorted for a couple of minutes before correcting. At times you can see the individual pixels. Sometimes...
Hello
Make sure TV is on the correct channel or input. Check the cables for correct routing from TV to any other devices. Check cables to ensure they are tight and secure.
An analog signal converted to high defintion resolution will cause lines, blurriness or fuzziness in the picture. Change the resolution to a lower or native setting using the media device (cable box, DVD,). This may be an issue that requires a service call to cable provider.
A problem on one channel may just be a error on that channel. If using an antenna, it might need to be adjusted in order to ensure good signal strength. For digtal channels, go into TV Menu. Check the DTV signal. Weak signal can cause picture distortion.
If another device is being used such as a cable box, DVD player or VCR switch between devices and test picture. Check routing of cables that are used to control the image. This should be a series of red, white and yellow cables.
If a VCR with a cable box, make sure the VCR and TV are set to the correct channels for video signal to pass through. If problem is still occuring, try another set of cables. bad cables can cause picture distortion.
Bad cables can cause picture distortion as well. Try another set of cables. If picture is better than when using the cables replaced, this was the issue. If cables are not an issue TV may require service.
Apr 26, 2011 | LG Televison & Video
LEFT SIDE OF PICTURE IS BLURRY AND COLORS DISTORTED
Does that set have whats called a color wheel, if so that maybe you problem, and replacement is how you fix it.
Apr 30, 2010 | Toshiba TP43H95 43" Rear Projection...
Plasma TV Picture Periodically Blurry/Color is Distorted
This sound more like a cable issue. Also check the leads going from your cable box to the set/ If you are using component cables one of them may be loose.
Apr 28, 2010 | Panasonic Viera TH-42PX80U Plasma TV
50' philips plasma tv has sound but picture is distorted
I sugest you to change the video resolution settings on the PS-3 to see if TV sets to any one resolution...if you have any other video out (analog from PS3)...connect the out to TV and check video at different resolutions. If PS3 has Deep Color settings turn it OFF.
Apr 10, 2010 | Philips 50PFP5332D 50 in. Plasma...
Color Blur
the cord inside that is connecting the power to the screen is loose just either call a repair man or reach inside and plug it in better.
Feb 12, 2009 | Samsung LTN226W 22 in. HD-Ready LCD...
Can't see picture
Is the onscreen menu just as distorted and are the lines across it or behind it? The pop you heard may have been a capacitor and since the TV is still powering on, it's the probably the video controller board that is on it's way out. If the onscreen menu looks fine, you maybe having a problem with the input board only so try a DVD that uses a different input and if it's poor, I would say the TV needs to have the input/output board service. If the OSD is distorted as well then it's definitely the video controller board and service is likely required.
Oct 15, 2008 | LG 42PX4DR 42 in. Plasma TV
Pictures are blurred........... HELP
When you reboot your computer, hold down the "Delete" key. This should take you to a black screen and multiple options like "Safe Mode", etc. Choose "Last Known Good Configuration" then see if that helps.
If the pictures on the Internet are blurred, it's most likely due to a setting in your router/modem or web browser that is loading the page with minimal image quality and size to make browsing faster.
Mar 28, 2008 | E-Machines eMachines Desktop PC
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Picture distorted and blurry with color
bad convergence amp ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Mitsubishi VS-60607 TV Logo
167 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
