Question about Panasonic PT-51HX41 51" Rear Projection Television
Convergence my panasonic big screens has blue all out of wack, like watching a 3d movie. Going into the setting menu will not bring it back in alignment. from reading in fixya it sounds like the "amp" is bad. can i change that part myself? Where could I order the part? thanks pc
  • willobrien Jan 17, 2008
    I just got the same TV with the same problem (except it's the red tube). I've ordered some new STK392-110's to swap in. I'm looking for the service manual so I can tweak the convergence settings once the amps are swapped out.
  • pajam_2008 Nov 20, 2008
    only need adjust convergencia
    Problem Solver:
  • 12 Answers
Pcjimbo, I have the service manual and chssis technical guide for your tv. If you need part numbers etc please let me knoe I can email them, fax, or scan and copy the info to you, if it will make it easier for you. Scott
Posted on Apr 18, 2007
  • Scott Nichols Apr 18, 2007
    Sorry about the spelling guys. Scott
    Sergeant:
  • 337 Answers
It does sound like the blue convergence amplifier IC,if you are familiar with soldering and unsoldering electronic components you can change it yourself,the first thing to do is identify the convergence IC's,all of the should have the same part number and start with STK--- ---,every set uses different numbers(amps).Is suggested you change all 3 of them at the same time and the average price for one is about 18.00 for the good ones.Once you know the STK number you can find them at www.partstore.com .If you are not too familiar with tv service you should seek the assistance of a servicer,sometimes you dont need to do adjustments after you replace the IC's but other times you need to get into the service menu and do some adjustments.Let Us know if you need more information.
Posted on Oct 27, 2006
  • Omar Urrutia
    Omar Urrutia Oct 27, 2006
    Your rating response is also important.
Picture like watching 3d movie. and bowing on side
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 16, 2011 | RCA P56950 56" Rear Projection Television
I have mitsubishi vs-50800 i was watching a movie and the screen just all of a sudden went blury and the color is all mixed up i went to the convergence menu and it wont allow me to move the colors left or...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 03, 2011 | Mitsubishi VS-50800 50" Rear Projection...
I turned my tv on this morning and the colors were all out of wack. the tv was producing an image similer to what an old 3d movie with the red and blue images. i tried reseting the tv to factory default...
  • Screen looks 3D, wavy, or has a shadow or shadows
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 22, 2011 | Philips Magnavox 51MP392H Rear Projection...
Hooked up PS3 to system and when watching DVD's the right side of the picture is blurry and appears doubled, like an old 3D movie without the red and blue glasses. When watching TV everything looks fine.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Picture looks like 3d i have ajusted screen but keeps going back to 3d and picture is bowed
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 25, 2010 | RCA P56923BL 56" Rear Projection...
My big screen tv looks 3d and red green blue are off
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
Mar 06, 2010 | Sony KP-51WS500 51" Rear Projection...
Convergence on Panasonic PT47WX42 is 3-D movie like and wavy...
you will need to replace both stk392-110 convergence ICs. You can get replacements at the following link with instructions. They also have the service manual for your set.
http://servicemanuals.vstore.ca/
Feb 05, 2009 | Panasonic PT-47WX49 47" Rear Projection...
RGB lamps are not aligned
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Jan 18, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
RED GREEN BLUE CONVERGENCE IS OUT.
if you have a rca hd56w66 chasis itc222 you may have the common fl231 fuse problem. I see this everday at the shop. to determine if you may have this problem. i have written a little article on this subject. Consult tips and tricks section under my profile. Going into maintence mode might have reset some settings.
Nov 24, 2008 | RCA HD56W66 56" HDTV
Mitsubishi 290p080020 big screen tv
•Screen looks 3D
Aug 30, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
76 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
