Question about BenQ PB7220 XGA DLP Projector Multimedia Projector
No menu or utility access - BenQ PB7220 XGA DLP Projector Multimedia Projector
It print all color blue
use the printer utilities
Using the Printer Utilities
how to
Accessing the printer software You can access the printer software from most Windows applications, or from the Windows Start menu.
When you access the printer software from a Windows application, the settings that you make apply only to the application you are using.
When you access the printer software from the Start menu, the settings that you make apply to all of your Windows applications.
Refer to the appropriate section below.
From Windows applications
Follow the steps below to access the printer software.
Click Print or Print Setup on the File menu. In the dialog box that appears, click Printer, Setup, Options, or Properties. (Depending on your application, you may need to click a combination of these buttons.) The printer software opens.
From the Start menu
For Windows Me, 2000, NT 4.0, 98 and 95 users, click Start, point to Settings, then click Printers.
For Windows XP users, click Start, then click Control Panel, then click Printers and other hardware, then click Printers and Faxes.
For Windows Me, 98, and 95 users, select your printer, then click Properties on the File menu.
For Windows XP and 2000 users, select your printer, then click Printing Preferences on the File menu.
For Windows NT 4.0 users, select your printer, then click Document Defaults on the File menu.
May 13, 2015 | Epson L210 - multifunction printer /...
How do I optimize my PC ?
Way too complex for FixYa, but start by doing a disc cleanup then a defragment (these are accessed from the accessories/system tools menu on your start menu)
Nov 14, 2014 | Computers & Internet
How to enter bios on thinkcentre 8811-6cu
Try hitting F2 when boot starts will normally take you to the bios.
Jun 14, 2011 | Lenovo ThinkCentre® M55-8811 PC Desktop
Lengthwise stripes when scanning or copying
Access the Main printer settings dialog box.
Click on the Utility tab/button and you will see the Utility menu.
Run the Nozzle Check (Windows), Confirmation (Macintosh) and it will print out a nozzle check pattern/confirmation as promted
Jan 10, 2011 | Epson TX300F Series
When i right click on any folder the particular window freezes saying not responding for atleast 5 min but i can access all other application or icons from desk top. im using win xp sp3
This issue is usually due to a bad context menu handler. When you right click on an object the context menu is called and any installed handler objects are called also. If one of the these additional objects are broken or missing, it slows the whole process to a crawl.
There is a utility that will allow you to see what context menu handlers are installed and it will also allow you to disable the individual context menu handler components.
As there are potentially numerous items, there can be a lot of choices. In my professional experience, if you have an older version of Office installed (Office 2000, Office XP, or Office 2003) sometimes the Microsoft Picture Manager can break the context menu.
Also look for any context objects that reference a tool but display "File Not Found" under the "Filename" column of the utility, as the operating system is trying to load something that is not there to load.
The utility is called ShellExView, it is created by NirSoft and can be found here at http://www.nirsoft.net/utils/shexview.html
Feb 24, 2010 | Microsoft Computers & Internet
What is the procedure for accessing the computer's Setup program on a Gateway E-6610D?
To Access the BIOS setup utility start the PC and press and hold the F1 key until the setup menu appears. This must be done before the Windows Logo appears.
Feb 02, 2010 | Gateway Computers & Internet
AOC 16" monitor is wide screen and stretches the display - how to fix?
Some where on you screen is a menu button that allows you to access teh screens utilities. One of teh utilities is the screen's geometry. Iti is here that you can adjust the length, width, position, etc.
You may want to access the vendors web site and sownload the user manual.
Oct 06, 2009 | AOC LM729 17" LCD Monitor
Blurry printing with brother 420cn printer
The print utility is accessed from the front panel menu button. The menu should be self explanatory.
Also check that the cartridge is pushed in fully so it's not sucking air through the system.
Feb 28, 2008 | Brother MFC 420CN All-In-One InkJet...
BenQ PB7220 XGA DLP Projector Multimedia Projector Logo
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
